Mon, Jan 6, 8:43 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: How to: Layered Makeup with PNGs, screen shots included
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 4:58 PM · edited Mon, 06 January 2025 at 8:34 PM
lotsa experimenting, success hoorah
Rynne8 came with make up pngs.
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 5:19 PM
top shader = layers list
WendyLuvsCatz ( ) posted Wed, 02 June 2021 at 5:28 PM
I find most things that use LIE actually load into Carrara correctly set up as layers, the problem is more to do with how it is saved by the PA in DAZ studio, the same as not all materials load from the browser.
Of course stuff that uses geometry shells you need to do manually.
Dreaming Kitty Channel
Tom R. Toe
My ArtyFarty AI channel
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 5:59 PM
lotsa manual labor.
manually creating head shape morphs for the eyelashes.
a few come with eyelash morph supports. Rynn8 came with an eyelash fit morph
trust the fairy lol
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 7:27 PM
more make up
the eyelash thing is getting ridiculous. i'm going into ds again to convert the autofits to support morphs in the eyelashes.
what she really needs is some carrara dynamic hair eyelashes. !!
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 8:35 PM
it doesnt work well with every make up. on some can see where the makeup didnt antialias
WendyLuvsCatz ( ) posted Wed, 02 June 2021 at 9:08 PM
I don't bother with the eyelashes in Carrara, if was doing a close up would try dynamic hair
Tom R. Toe
MistyLaraCarrara ( ) posted Wed, 02 June 2021 at 9:58 PM
i'm saving the character to carrara. don't want to worry down the line about eyelashes fitting. doh.
bummed the make up layers are hit or miss. the white bits are supposed to be invisible.
MistyLaraCarrara ( ) posted Mon, 14 June 2021 at 11:43 AM
there prolly a way to blend away the white ring round her iris.
MistyLaraCarrara ( ) posted Mon, 14 June 2021 at 12:31 PM
oh mann no frikkin way
found the makeup problem.
instead of loading the makeup to the blend channel the long way, i was doing right click copy on the make up png from the source 2 channel and pasting it into the blend channel. only it doesnt just paste in the texture path, it pastes in the other tick settings.
dohhh.
the blend channel is alpha only. where as the source2 is color + alpha
sunnofabee
MistyLaraCarrara ( ) posted Mon, 14 June 2021 at 12:53 PM
hurrah
http://static.skaip.org/img/emoticons/180x180/f6fcff/handsinair.gif
MistyLaraCarrara ( ) posted Mon, 14 June 2021 at 1:43 PM · edited Mon, 14 June 2021 at 1:49 PM
Layed Makeup Steps from the Top using Rynne 8
1 top shader set to Layers List
2 Next level set to Basic
3 Shader = multichannel
4 Color = Mixer
5 Source1 = face detail (under the makeup)
options set to 'color only'
6 Source 2 = makeup png
options set to 'color and alpha'
7 Blender = Texture map, load the makeup png again
options set to ;alpha only'
Rynne makeup 02
MistyLaraCarrara ( ) posted Mon, 14 June 2021 at 2:02 PM
having no luck loading screenshots today.
try again.
Step 4
Step 5
headwax. ( ) posted Tue, 15 June 2021 at 12:09 AM
you Rock! another terrific tut !
diomede ( ) posted Thu, 17 June 2021 at 11:36 AM
Thank you!
