Wed, Feb 19, 4:33 PM CST
Forum Moderators: RedPhantom
Subject: Is there an add-on "exploder" program for Poser 11?
vxg139 ( ) posted Fri, 11 June 2021 at 11:14 PM ยท edited Tue, 18 February 2025 at 3:30 AM
Hi,
Just curious if there is an add-on program to Poser 11 that would break "props" into (user defined) number of segments... similar to PhilC's "Exploder"? I can't get PhilC's "Exploder" to work with Poser 11 ...hence my question!
Thank you all for your support/advice. :c))
EldritchCellar ( ) posted Sat, 12 June 2021 at 4:34 PM
Just because no one has answered...
I haven't seen a replacement for that. You might try asking this same question over in the Poser Python forum, there's a member by the name of ADP that frequents there that might find it interesting. Who knows he might whip up some code similar?
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:06 PM
so I did a little looking around and recalled that a member named Ockham had an Exploder Script tucked away on his site. I was doubtful it would work in Poser 11 but after some testing, turns out it works. I'll post a mini tutorial on how to use it... First you'll need the script, which can be found here...
http://ockhamsbungalow.com/Python/
it's about halfway down the page.
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:09 PM
Then you'll need the free version of UVMapper classic which can be found here...
http://www.uvmapper.com/downloads.html
vxg139 ( ) posted Sat, 12 June 2021 at 5:21 PM
EldritchCellar.. you are true STAR~! Thank you so much for your help.... :c)))
Kindest Regards,
vxg139
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:23 PM
Ok. Load/import the model you want to explode, in this case I'm going to be using a low poly ant model that I have...
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:35 PM
Sorry, you want to run the model through UVMapper Classic first. Load the model in UVMapper Classic, go to Edit menu: Tools: Split Vertices. Save your Model. THEN import into Poser...
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:42 PM
Back in Poser Select the model and run the Python Script. I just ran it through File: Run Python Script... The script has some options, see the ReadMe that comes with the script
EldritchCellar ( ) posted Sat, 12 June 2021 at 5:46 PM
This will generate a morph target called explode in the model... dial to taste.
Sorry so sloppy, in the middle of working in another program. Glad I could help.
vxg139 ( ) posted Sat, 12 June 2021 at 5:52 PM
You are truly awesome! Do you have a store at Renderosity?
EldritchCellar ( ) posted Sat, 12 June 2021 at 6:05 PM
No. Maybe sometime in the future, more than likely. Kind of obsessed with JCMs and morphs in an old abandoned free japanese figure at the moment. I have a bunch of unfinished commercial target things for La Femme. I'll probably resume that once finished my current project... or resume building another free figure that I was working on. I like to tinker. I appreciate you asking though, it's very kind.
vxg139 ( ) posted Sat, 12 June 2021 at 6:09 PM ยท edited Sat, 12 June 2021 at 6:12 PM
Well.. should you develop clothing/accessories/skin textures for V4, just let me know! :c)) 10+ years on, and still prefer V4 to any other characters (new or old)!...She is an eye catching character + can be used directly in Poser!!! :c)))
I have pretty much purchased everything for V4 (both here and DAZ3D)! :c)))
Thanks again for your awesome help....
Kindest regards,
vxg139
EldritchCellar ( ) posted Sat, 12 June 2021 at 6:20 PM
She's a good figure, I like V4 too. Karina's Sasha 16 is my preferred flavor for pin up type stuff.
Take care.
randym77 ( ) posted Sat, 12 June 2021 at 6:39 PM
You might be able to get an update to PhilC's Exploder script. You could email him and ask.
SamTherapy ( ) posted Mon, 14 June 2021 at 8:14 AM
AFAIK, Phil retired a while ago.
EldritchCellar ( ) posted Mon, 14 June 2021 at 8:32 AM
He did. He might still answer queries though, says he still does support for Wardrobe Wizard... ?
wolf359 ( ) posted Wed, 16 June 2021 at 2:37 AM
Too bad the poser physics plugin was never updated.
My website
randym77 ( ) posted Wed, 16 June 2021 at 5:02 AM
Wow, PhilC really did retire. He was still selling stuff in his store not long ago, but now the store's closed.
I know he did update the Exploder script awhile back, so it would work with new versions of Poser, but I don't know if that includes Poser 11. Definitely doesn't include Poser 12.
