Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Just because no one has answered...
I haven't seen a replacement for that. You might try asking this same question over in the Poser Python forum, there's a member by the name of ADP that frequents there that might find it interesting. Who knows he might whip up some code similar?
so I did a little looking around and recalled that a member named Ockham had an Exploder Script tucked away on his site. I was doubtful it would work in Poser 11 but after some testing, turns out it works. I'll post a mini tutorial on how to use it... First you'll need the script, which can be found here...
http://ockhamsbungalow.com/Python/
it's about halfway down the page.
Then you'll need the free version of UVMapper classic which can be found here...
http://www.uvmapper.com/downloads.html
Ok. Load/import the model you want to explode, in this case I'm going to be using a low poly ant model that I have...
Sorry, you want to run the model through UVMapper Classic first. Load the model in UVMapper Classic, go to Edit menu: Tools: Split Vertices. Save your Model. THEN import into Poser...
Back in Poser Select the model and run the Python Script. I just ran it through File: Run Python Script... The script has some options, see the ReadMe that comes with the script
This will generate a morph target called explode in the model... dial to taste.
Sorry so sloppy, in the middle of working in another program. Glad I could help.
No. Maybe sometime in the future, more than likely. Kind of obsessed with JCMs and morphs in an old abandoned free japanese figure at the moment. I have a bunch of unfinished commercial target things for La Femme. I'll probably resume that once finished my current project... or resume building another free figure that I was working on. I like to tinker. I appreciate you asking though, it's very kind.
Well.. should you develop clothing/accessories/skin textures for V4, just let me know! :c)) 10+ years on, and still prefer V4 to any other characters (new or old)!...She is an eye catching character + can be used directly in Poser!!! :c)))
I have pretty much purchased everything for V4 (both here and DAZ3D)! :c)))
Thanks again for your awesome help....
Kindest regards,
vxg139
She's a good figure, I like V4 too. Karina's Sasha 16 is my preferred flavor for pin up type stuff.
Take care.
He did. He might still answer queries though, says he still does support for Wardrobe Wizard... ?
Hi,
Just curious if there is an add-on program to Poser 11 that would break "props" into (user defined) number of segments... similar to PhilC's "Exploder"? I can't get PhilC's "Exploder" to work with Poser 11 ...hence my question!
Thank you all for your support/advice. :c))
