Sat, Feb 8, 1:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Subject: Poser 11 suddenly slow
Offie56 ( ) posted Thu, 18 February 2021 at 11:28 PM ยท edited Sat, 08 February 2025 at 1:26 AM
Hi there in the forum,
maybe someone can help me. I am using Poser Pro 11 pro, and have a new problem since yesterdey. First of all: I havenโ€˜t changed anything in the whole set up. I am a quite experienced user but not an expert. The problem is - especially with Victoria 4, that poser โ€ž freezesโ€œ for about 5 Seconds when I change between the figures or commands. After that freeze it works again. That is horrible for the workflow. I think the program needs time to load something and the delay in the past was there but o.k. 1 Second or so. But now: Click wait.....click.....wait.....click...wait. Maybe somebody knows that issue and can help me with it Thank you so muchh Regards Offie
rokket ( ) posted Thu, 18 February 2021 at 11:49 PM
Sometimes windows updates mess up Poser a lot. You didn't state if you were on a PC or MAC, but that's been my experience.
ironsoul ( ) posted Fri, 19 February 2021 at 6:48 AM
Both joker2000 and myself have had an issue with KB4601319 impacting performance (maybe in my case KB4601050 too). If you're a Windows 10 user its worth checking if you've received the KB4601319 patch and if it coincided with the loss in performance.
Offie56 ( ) posted Fri, 19 February 2021 at 7:06 AM
Thank you ironsoul, I 've got the update. Unfortunately windows tells me that I am not able to return to the older Version because the update is older than 10 days??? What? Thanx again Windows
twajjo ( ) posted Thu, 10 June 2021 at 11:11 PM
Thanks for posting this, hit me too almost at the same time, been wondering what's up for a couple of months. Any remedy?
ShaneNewville ( ) posted Fri, 11 June 2021 at 9:10 PM ยท edited Fri, 11 June 2021 at 9:11 PM
ironsoul posted at 9:07PM Fri, 11 June 2021 - #4413267
Im running into this too. It has affected all versions of Poser that I have...except for Poser Pro 7 (ironically). I'm also on Windows 10 and removed every update that I could, but it didn't help. I do not see any of the 3 updates on my system that you mentioned above (KB4601319, KB4601050, KB4601319), unless its one of these that show no number:
Uninstalled with no affect:
Microsoft  Visual C++ 2010 x64 Redistributable (KB2565063)
Microsoft  Visual C++ 2010 x86 Redistributable (KB2565063)
Feature Update to Windows 10 21H1 viea Enablement Package (KB5000736)
Update for (KB2504637) - MS .NET Framework 4 Multi-Trageting Pack
Update for Microsoft Windows (KB4584229)
Update for Microsoft Windows (KB5003254)
Update for Microsoft Windows (KB4601554)
Not Uninstall (Option is disabled/hidden):
Security Update for Adoble Acrobat X (10.1.1)
Security Update for Adobe Flash Player
Security Update for Microsoft Windows (KB4566785)
Security Update for Microsoft Windows (KB4570334)
Security Update for Microsoft Windows (KB4593175)
Security Update for Microsoft Windows (KB5003173) (allowed, but fails with error)
Servicing Stack 10.0.19041.985
Update for Microsfot Windows (KB4565627)
Update for Removal of Adobe Flash Player
Hope it gets fixed soon. On Windows 7 I am not having any slow down issues.
_____________________________
My most recent Poser animation:
Previs Dummies 2
nerd ( ) posted Sun, 13 June 2021 at 4:54 AM
Forum Moderator
Probably not seeing KB4601319 because it's been further updated no fewer than 11 times. At least according to the MS updates site. The following updates superseded KB4601319
  • 2021-02 Cumulative Update Preview for Windows Server, version 20H2 for x64-based Systems (KB4601382)
  • 2021-03 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5000802)
  • 2021-03 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5001567)
  • 2021-03 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5001649)
  • 2021-03 Cumulative Update Preview for Windows Server, version 20H2 for x64-based Systems (KB5000842)
  • 2021-04 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5001330)
  • 2021-04 Cumulative Update Preview for Windows Server, version 20H2 for x64-based Systems (KB5001391)
  • 2021-05 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5003173)
  • 2021-05 Cumulative Update Preview for Windows Server, version 20H2 for x64-based Systems (KB5003214)
  • 2021-06 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5003637)
  • 2021-06 Cumulative Update for Windows Server, version 20H2 for x64-based Systems (KB5004476)
So good luck figuring out how to roll that back. Thanks Microsoft.
Eronik ( ) posted Tue, 15 June 2021 at 12:16 PM
Might not be exactly the same thing, but this click... wait 1sec ... move happened to me to. I'd click on a body part and had to wait a sec before it moved.
The solution for me was to reset Poser's Launch To... option to factory scene in the General Preferences (Ctrl+K). Maybe it will work for you too Offie.
SatiraCapriccio ( ) posted Wed, 16 June 2021 at 2:10 PM
It's as much as 30 seconds (or more) once I've injected morphs. Whether it's selecting another object in the scene or selecting a camera, trying to change a parameter or rotate or move a camera. Creating poses and setting up dynamic cloth simulations is painful.
However, I am glad to know it's not an problem with my installs, but a Windows update problem. But, if we have to wait until Microsoft fixes whatever the update broke, we could be waiting a really, really long time.
Is Bondware checking into it?
Sadly, resetting to factory scene seemed to be a temporary fix
Burning within each of us are Fires of Creativity
Satira Capriccio
SamTherapy ( ) posted Sat, 19 June 2021 at 8:55 AM
Something else that can impact on your PCs performance, believe it or not, is dust.
We like to keep our house clean and tidy but - particularly having cats - dust is a fact of life. I take my computer apart every few months and give it a clean, removing dust that's collected around the fans and heatsinks and so on. As you probably know, the hotter a computer gets, the slower it runs.
If any of you are still silly enough to smoke - I quit 10 years ago - you'll find a lot of sticky stuff in there, too, which is really unpleasant.
May not necessarily make Poser run faster but it will do your computer a huge favour.
Obviously, you can ignore all the above if you have a sealed, cryo cooled machine. :)
