Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
If you hide the ground/construct (ctrl-g) you will still have a background color which can be changed by clicking on the highlighted circle. To not have this show up, you need to save your image as a png or tiff, then that selected background color will be transparent (in your saved image file).
Consider me insane if you wish, but is your reality any better?
I never liked the Construct, so I set up my Startup Scene to use the Poser 10 Workspace.pz3. Then just save your renders in .png format, and you'll always have a transparent background.
You can find it at Libraries > Scene > Poser 11 Environments > Poser 10 Workspace
Then just go into Edit > General Preferences and set Launch Behavior to Launch to Preferred Scene and click the Set Preferred Scene button. Then go to the Interface Tab and set Launch Behavior to Launch to previous state. Click the OK button at the bottom right to save your preferences. Then save a scene called Startup, and then close P12 and relaunch it to test that the setup worked.
Then you'll never have to worry about the unwanted backgrounds again.
_______________
hello I'm pretty ne to poser and am just trying the trial of poser 11 i have a question to ask because i'm thinking about buying the program how do you remove the background setting's to a transperant background i don't whish to have a background at ll just the poser or prop i ca't find this setting some people are saying you can't do this in poser
