Fri, Oct 4, 12:24 PM CDT
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Sep 30 4:44 pm)
Subject: Another question, simple, I hope.
MikeMoss ( ) posted Thu, 05 August 2021 at 6:06 PM ยท edited Fri, 04 October 2024 at 10:31 AM
How do you clear the lights, in Poser 12 every time I select a light set it adds it to what is already there. It always replaced the previous set with the new one before. How can I get rid of them without deleting them one at a time, and how can I get it to replace what's already there as it did before.
By the time I realized what was happening, I had 17 lights on!
If you shoot a mime, do you need a silencer?
Y-Phil ( ) posted Thu, 05 August 2021 at 6:39 PM
From what I just tested a few seconds ago: instead of double-clicking on a light set, select it in the library window and then click on the single "V". If you hover this symble, it displays a message stating that it will replace.
Furthermore, in the menu Scripts > Utility, you will find "deleteLights". It's a scripts that will remove them all in one shot.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
hborre ( ) posted Thu, 05 August 2021 at 9:48 PM
Online Now!
This was a feature that was incorrectly set up in previous versions of Poser and has been 'corrected' now. The instructions have been outlined in the previous post.
MikeMoss ( ) posted Fri, 06 August 2021 at 10:06 AM
Thanks, it's been kind of a pain having to delete them on at a time. I had to do 23 of them yesterday.
Y-Phil ( ) posted Fri, 06 August 2021 at 10:43 AM
Oh by the way, most of the time, I'm parenting my lights using Poser's Group object. That way, if I want to remove only some, I delete the group using Poser's "Object > Delete object" menu entry.
Furthermore, I've even saved in my "Lights" runtime, a few props containnig each a group with a few parented lights. That way, I can load some predefined setups quite fast.
For exemple: "Pose lights" is a group containg three infinite lights, each diffusing... no light, and no shadows ("Shadows" ubchecked)
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
hborre ( ) posted Fri, 06 August 2021 at 10:56 AM
Online Now!
That's an ingenious way of organizing light presets. I have a runtime dedicated to lights only that is very underutilized. I should revisit it and do something constructive with it. You could also create specific folders under the favorites tab for your most favorite or utilized set-ups. The best part of this arrangement is that you can access it from any runtime in your library and can be easily transferred or copied to a new version of Poser.
MikeMoss ( ) posted Fri, 06 August 2021 at 4:43 PM
Thanks, I'll go through this with Poser open and figure it out.
