Poser 12 F.A.Q (Last Updated: 2024 Sep 30 4:44 pm)
From what I just tested a few seconds ago: instead of double-clicking on a light set, select it in the library window and then click on the single "V". If you hover this symble, it displays a message stating that it will replace.
Furthermore, in the menu Scripts > Utility, you will find "deleteLights". It's a scripts that will remove them all in one shot.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
Oh by the way, most of the time, I'm parenting my lights using Poser's Group object. That way, if I want to remove only some, I delete the group using Poser's "Object > Delete object" menu entry.
Furthermore, I've even saved in my "Lights" runtime, a few props containnig each a group with a few parented lights. That way, I can load some predefined setups quite fast.
For exemple: "Pose lights" is a group containg three infinite lights, each diffusing... no light, and no shadows ("Shadows" ubchecked)
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Nas 10TB
That's an ingenious way of organizing light presets. I have a runtime dedicated to lights only that is very underutilized. I should revisit it and do something constructive with it. You could also create specific folders under the favorites tab for your most favorite or utilized set-ups. The best part of this arrangement is that you can access it from any runtime in your library and can be easily transferred or copied to a new version of Poser.
How do you clear the lights, in Poser 12 every time I select a light set it adds it to what is already there. It always replaced the previous set with the new one before. How can I get rid of them without deleting them one at a time, and how can I get it to replace what's already there as it did before.
By the time I realized what was happening, I had 17 lights on!
If you shoot a mime, do you need a silencer?
