Fri, Jan 31, 11:31 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 26 3:18 pm)
Subject: Comparing CPU and GPU renders
AcePyx ( ) posted Fri, 06 August 2021 at 8:09 PM ยท edited Wed, 29 January 2025 at 4:19 PM
Does anyone know if there's a formula for CPU-based branched path rendering and GPU non-branched path to achieve exactly the same quality? I tried 10 and 40 and whilst the image quality appeared the same, there is a lot more bounced light with the branched path render.
Thank you in advance.
wimvdb ( ) posted Sun, 08 August 2021 at 11:43 PM ยท edited Sun, 08 August 2021 at 11:45 PM
Branched and non-branched path renders use a different approach and they also treat materials differently. Blender - Branched path tracing explained shows the difference between the two and what influence the sample and bounce settings have on each.
Miss B ( ) posted Mon, 09 August 2021 at 9:40 AM
Thanks for that link Wim. As a Blender user, this will be doubly useful info for me. ๐Ÿ™‚
_______________
Butterfly Dezignz
AcePyx ( ) posted Mon, 09 August 2021 at 1:28 PM
wimvdb posted at 1:24PM Mon, 09 August 2021 - #4424823
Thank you Wim. Yes, this does partially illustrate (if not explain) why the lighting is different, but in no way helps me in determining a conversion formula, leaving me simply to eyeball it. Worse still, his approach of test rendering EVERY SINGLE SCENE with multiple settings is ridiculously impractical, AND Poser does not allow you to separate out the channels to see the impact in detail like Blender does. But thank you anyway.
wimvdb ( ) posted Mon, 09 August 2021 at 3:07 PM
It does not give a formula - correct. It does show however which bounce settings are important. It also shows you that a formula is rather difficult to determine since the branch path and non branched path renderers acting differently depending on the nodes used (blend for glossy/diffuse for instance). But the main reason I showed the video link is to explain the difference in light bounces.
I do support you with wanting to have additional render layers for spec, light, shadow, indirect light, etc. Those are very helpful.
AcePyx ( ) posted Mon, 09 August 2021 at 6:06 PM
wimvdb posted at 6:05PM Mon, 09 August 2021 - #4424876
Indeed. Thanks again Wim!
ghostship2 ( ) posted Tue, 10 August 2021 at 4:16 PM
for renders you want to kick diffuse bounces up to 6. This is about the limit that I can tell a difference and should give you maximum light bounces in your scene. It is especially apparent when using the GROUND/Construct in your scene.
AcePyx ( ) posted Tue, 10 August 2021 at 4:36 PM
ghostship2 posted at 4:35PM Tue, 10 August 2021 - #4424989
Thank you Ghost - appreciate you sharing your experience.
NikKelly ( ) posted Sat, 04 September 2021 at 10:15 AM
Slightly tangential: I prefer Superfly 'progressive' as I can quickly see if scene will 'work'. Also, same results on this CAD Tower's twin GPU cards, its CPU-only, or networked 'Box' CPU-only...
(#1 is fast within now-ageing cards' complexity limits. #2 is reliable but, even as 'background', slows PC. #3 is 'Whoosh'...)
AcePyx ( ) posted Sat, 04 September 2021 at 11:44 AM
NikKelly posted at 11:43AM Sat, 04 September 2021 - #4426627
Slightly tangential: I prefer Superfly 'progressive' as I can quickly see if scene will 'work'. Oh yes - 100%
