Poser 12 F.A.Q (Last Updated: 2025 Jan 17 2:50 pm)
Did you delete the "extra" node that the background loads with by default? The background works fine if I leave them. It reverts when I remove them. By extra nodes, I mean BC Color, Black, BG Environment, BG Picture, and BG Movie.
And today's fun fact, the ground plane shadow catcher works well if you're using the background rather than a sphere.
I confirm this automatism: the background's defaults nodes must be present, even if they are not used, and it's also in Poser 11. Example in Poser 12 (same effect in Poser 11)
You don't even need to get out of the Material room: select another object, and then come back to the background node.
๐ซ๐ฝ๐๐
(ใฃโโกโ)ใฃ
๐ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐ฟย Nas 10TB
๐ฟย Poser 13 and soon 14ย โค๏ธ
This is nothing new. It was in poser 7. If I had to guess, it has something with being able to set a background color in the pose room. I like to have my background set to green for higher contrast. Even when I set up a background image, the background stays green in the pose room.
I don't think I've ever tried removing them. I usually just unplugged whichever one was plugged in, minimized them size-wise, and moved them out of the way.
_______________
Le sigh. So I went back to test Ghostship's wonderful materials and lights by setting up the background node the way he explains in his tutorial.
I did the setup, exited the material room, it looked great. Then I entered the mat room again to adjust a setting on my model's eye texture. Surprise! When I moved back to the Pose Room the background node I set up was disconnected and the original default setup was auto-plugged in back.
This is very bizarre. I retested twice. This happened after a Windows 10 update so no idea what got messed up. Will file a bug report regardless. Just wanted to see if anyone manages to replicate.
