Thu, Dec 26, 9:51 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 26 8:06 pm)
Subject: Read sticky post here about Installing Zip files into Daz Studio. Help
starlight64 ( ) posted Sat, 07 August 2021 at 9:35 PM · edited Thu, 26 December 2024 at 9:51 PM
Hi, I just read the Sticky post mentioned above. I have no clue where to look I guess but I can't find any figures in My Library folders mentioned in the post. Not even the Genesis figures that I know are there. Are they hiding the folders somewhere? I'll attach a snip of the path and what I see. thanks! DazMyLib.JPG
starlight64 ( ) posted Sat, 07 August 2021 at 9:38 PM
starlight64 ( ) posted Sat, 07 August 2021 at 9:48 PM
hborre ( ) posted Sat, 07 August 2021 at 10:34 PM
Your content will not be found within the Program Files folder. This is a restricted area that Windows has set up to prevent sharing. The 1 location should be under Users>Public>Public Documents, this is where your content should go, and the other should appear under Users>[your name]>Documents>DAZ3D>Studio>My Library. In my case, any content obtained from Renderosity is checked beforehand and unzipped to a different folder called My DAZ 3D Library; this folder was created by DAZ Install Manager and it is how I install content directly from DAZ3D.com.
starlight64 ( ) posted Mon, 16 August 2021 at 2:34 PM
Actually I found the correct folder . I however watched a video where the guy dragged and dropped into the supposedly correct folders. I looked very carefully and put them in the places I knew for a fact had content in it that shows up but still not working. :-( Someone told me to get a script from here but not sure how to use even if I could find it. So install manager installs the files from here? How do you do that? My install manager won't even recognize files I downloaded from here. Also, It doesn't always install Daz files It downloaded from their site. | Granted the files are older.. more than 12 yrs or more But I use to belong to PC and have tons of products from there and they are their products. Thank you for your reply and any additional advice is deeply appreciated.
hborre ( ) posted Mon, 16 August 2021 at 3:36 PM
DIM (DAZ Install Manager) will only install zip files exclusively from DAZ3D because those files are specially constructed for DIM and follow a particular hierarchy for installation. Rendo does not follow that format.
