Mon, Dec 23, 12:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Subject: help please
Sa_raneth ( ) posted Sat, 04 September 2021 at 7:15 PM ยท edited Mon, 23 December 2024 at 12:07 AM
need help getting Vicki 4.2 into poser 12 seems as when i unzip it dont go where it is supposed to in poser any help is greatly appreciated
Rhia474 ( ) posted Sat, 04 September 2021 at 7:27 PM
There is a Content folder above the Runtime when you unzip a DAZ zipped folder so the automatic unzip of Poser's File menu won't work. I suggest to manually unzip and then place unzipped folders into whichever runtime you want it , using your Windows Explorer.
Disclaimer: if you use Mac, I can't help.
randym77 ( ) posted Sat, 04 September 2021 at 7:27 PM
If you've got a zip file, open the "content" folder in the zip file, then extract the folder called "runtime" and put that where you want to put Vicky.
If you've already extracted the "content" folder, just move the "runtime" folder that's inside the "content" folder to where you want it.
Then you have to run the .bat file to initialize her morphs, but we'll worry about that after you get her installed.
Also, make sure you downloaded the right file. There are three versions. For Poser, you want the file called IM00004783-01_Victoria42Base.zip.
Sa_raneth ( ) posted Sat, 04 September 2021 at 8:07 PM
that part went smoothly thanks bunches now for morphs++
Rhia474 ( ) posted Sat, 04 September 2021 at 8:12 PM
Should do the same, and then initialize again, like randym77 says above.
Sa_raneth ( ) posted Sat, 04 September 2021 at 8:20 PM
ok will let you know thanks
Sa_raneth ( ) posted Sat, 04 September 2021 at 8:41 PM
well all seems to be working fine thank you both very much
