There is a Content folder above the Runtime when you unzip a DAZ zipped folder so the automatic unzip of Poser's File menu won't work. I suggest to manually unzip and then place unzipped folders into whichever runtime you want it , using your Windows Explorer.
Disclaimer: if you use Mac, I can't help.
If you've got a zip file, open the "content" folder in the zip file, then extract the folder called "runtime" and put that where you want to put Vicky.
If you've already extracted the "content" folder, just move the "runtime" folder that's inside the "content" folder to where you want it.
Then you have to run the .bat file to initialize her morphs, but we'll worry about that after you get her installed.
Also, make sure you downloaded the right file. There are three versions. For Poser, you want the file called IM00004783-01_Victoria42Base.zip.
need help getting Vicki 4.2 into poser 12 seems as when i unzip it dont go where it is supposed to in poser any help is greatly appreciated
