To OP
You might try this on V4. It'll noticeably improve V4's skin. Its a python script... EZSkin 3. You want to use version 3 with Poser 11, not version 3.1 which is for Poser 12. There's options for regular Firefly IDL and Superfly material conversions...
https://cobrablade.net/snarlygribbly/poser.html
If you are having problems running EZSkin 3 in 11, download this patch for 11 by the same author, it's painless to install and it should sort any script problems you are encountering. The DL link is down the page a ways...
AVFix
https://www.poserlounge.nl/PLWP/
Yes, the Poser 12 thread with Y-Phil's suggestions. Never seen any DIS-advantage to having it off. I don't think there is.
Speaking of which, the topic made me actually look at my card settings (I run Poser on the GPU) and just now discovered that AO is OFF. Which would explain a lot lol. I'll just leave it off for now, otherwise I'll be spending an hour seeing if V4 turns blue from AO too ;)
Thanks for compelling me to look at that, I love the preview renderer so any option to further enhance it is welcome :)
It's really handy to have a preview that's at the resolution of target textures when painting textures, I make a detail change in photoshop, save a copy in iterations, and reload textures in render settings. It's instant feedback when I make an element movement or addition like I'm doing right now with these Black Metal Corpse Paint WIP type makeups I'm working on for La Femme... Usually the actual realtime preview is good enough to work by, rendering it through preview renderer is just if I want to see it anti aliased. Preview render takes about 2 seconds, useful for toons and animation also; probably it's biggest advantage.
primorge posted at 4:25PM Sun, 12 September 2021 - #4427196
To OP
AVFix
Do you know if these will work on a Mac? Sadly I don't have a PC with me at the moment
primorge posted at 11:21PM Sun, 12 September 2021 - #4427267
some Python scripts won't run on Mac. I don't know enough about Python to say why...
It's probably the Tkinter. So far as I know all Tkinter-based PoserPython scripts stopped running on a Mac after Poser Pro 2014 SR3, due to changes at Apple. They still work fine on Windows.
I don't know how it happened but I was working on a scene in Poser and the preview suddenly changed. It went from resembling the render to looking completely different. I'm not sure what happened for it to be like this. My scenes still render fine but I was wondering if anyone ran into this issue too and would be willing to help me out. Thank you all so much.
