Tue, Nov 19, 9:41 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2024 Nov 19 6:44 am)
Subject: Poser 11 lights
fldrummerman ( ) posted Fri, 08 October 2021 at 12:50 PM · edited Tue, 19 November 2024 at 9:26 AM
I had Poser 10 and the lights worked just fine. I could create a perfectly round yellow light that cast a very well defined shadow without rendering. In Poser 11, I can't get anything but a strangly shaped light that will not cast a shadow. What am I doing wrong????
hborre ( ) posted Fri, 08 October 2021 at 12:57 PM
What are your shaders in P10?  Are you using the same for P11?  This is assuming that you are still using Firefly.
RedPhantom ( ) posted Fri, 08 October 2021 at 1:50 PM
Site Admin
Poser 11 also switched from a flat ground plane to a domed construct. That might be causing issues.
bagginsbill ( ) posted Thu, 18 November 2021 at 7:51 AM
undefined posted at 12:50 PM Fri, 8 October 2021 - #2966064
It would help a lot if you showed what you're doing. Since you didn't, I would say there are an infinite number of things you did wrong.
My guess? You're not in OpenGL display mode, but rather in SreeD?
Right click on the preview window and check.
bagginsbill ( ) posted Thu, 18 November 2021 at 7:58 AM
2nd guess? You have shadows turned off on your light.
3rd guess? Your light is set to Diffuse IBL.
