New Poser Users Help F.A.Q (Last Updated: 2024 Oct 01 9:30 am)
Poser 11 also switched from a flat ground plane to a domed construct. That might be causing issues.
undefined posted at 12:50 PM Fri, 8 October 2021 - #2966064
It would help a lot if you showed what you're doing. Since you didn't, I would say there are an infinite number of things you did wrong.I could create a perfectly round yellow light that cast a very well defined shadow without rendering. In Poser 11, I can't get anything but a strangly shaped light that will not cast a shadow. What am I doing wrong????
My guess? You're not in OpenGL display mode, but rather in SreeD?
Right click on the preview window and check.
2nd guess? You have shadows turned off on your light.
I had Poser 10 and the lights worked just fine. I could create a perfectly round yellow light that cast a very well defined shadow without rendering. In Poser 11, I can't get anything but a strangly shaped light that will not cast a shadow. What am I doing wrong????
