Fri, Jan 24, 2:31 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 24 1:47 pm)
Subject: Poser Release 12.0.703 Now Available
tim ( ) posted Wed, 13 October 2021 at 3:04 PM ยท edited Fri, 24 January 2025 at 2:29 PM
Site Admin
The Poser Dev Team is pleased to announce that Poser 12.0.703 is available for download.
Release article: https://www.posersoftware.com/article/538/poser-update-poser-120703-improves-usability-and-material-room-performance
Full release notes and download links: https://www.posersoftware.com/downloads
This is a free update for anyone with a Poser 12 license.
Y-Phil ( ) posted Wed, 13 October 2021 at 3:56 PM
That's great news.
I've just read the release TXT file, and it doesn't seem to list any update on those RTX crashes that occurs sometimes. Is there any news?
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
๐Ÿ‘ฟย Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
๐Ÿ‘ฟย Nas 10TB
๐Ÿ‘ฟย Poser 13 and soon 14ย โค๏ธ
tim ( ) posted Wed, 13 October 2021 at 4:09 PM
Site Admin
Checking with support/testing folks.  Will let you know.
Y-Phil ( ) posted Wed, 13 October 2021 at 5:08 PM
tim posted at 4:09 PM Wed, 13 October 2021 - #4428884
Checking with support/testing folks.ย  Will let you know.
Thank you, Tim.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
EVargas ( ) posted Wed, 13 October 2021 at 7:54 PM
Thank you guys, I'm happy to hear the news!
EVargas.Art
RedPhantom ( ) posted Wed, 13 October 2021 at 8:12 PM
Site Admin
It's got a collapsable hierarchy! Thanks so much for that!
tim ( ) posted Wed, 13 October 2021 at 8:44 PM
Site Admin
@Y-Phil unfortunately, we have not been able to resolve the specific RTX crash during render you mentioned here and in your support ticket.  It occurs deep in the Cycles code.  The good news is that Stefan Werner has rejoined the dev team.  He is a Cycles expert and is working on updating Poser's Cycles & Optix to latest stable version.
ChromeStar ( ) posted Wed, 13 October 2021 at 11:38 PM
Yeah, my current scene is still giving those CUDA errors during Optix renders too (even in the new version). Fortunately they work OK as non-Optix GPU renders, so it's not as bad as having to resort to CPU rendering.
I didn't look at the collapsible hierarchy yet but that sounds great. Also sounds like some of the material room issues are resolved.
Y-Phil ( ) posted Thu, 14 October 2021 at 1:44 AM
@Tim thank you for the good news.
@ChromeStarย I've remarked that we can lower the risk of crash with cycles-based material during an rtx-based render by being sure that every character is unimesh and by being sure that nothing seems to cross, this last point being particularly true with the hairs. Unfortunately, some hairs still seem to have wrong geometries or errors in it. I suppose that this is where the rtx-based renders are crashing.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
dompie ( ) posted Thu, 14 October 2021 at 2:01 PM ยท edited Thu, 14 October 2021 at 2:01 PM
Hi,
I just installed the update but there seems to be something off with the Area lights rendering.
The scene rendered in P12:
The same scene rendered in P11 (lighting as I would expect it):
Did something change in the update regarding the use if Area Lights? (even if I turn up the intensity to 1000% the scene becomes barely lighter). I am using the 'Low Branched' preset in both P12 and P11
hborre ( ) posted Thu, 14 October 2021 at 2:29 PM
You'll need to make sure nothing has changed and if you can test drive other scenes in both versions, submit a ticket.ย  Sometimes the techs will break something while fixing something else.ย  Maybe if someone else notices a difference, they can verify the problem.
Rhia474 ( ) posted Thu, 14 October 2021 at 2:46 PM ยท edited Thu, 14 October 2021 at 2:46 PM
Sorry, can't reproduce; tested with single area light, one figure and dome in P11 and P12 and apart from the fact that Low Branched produces horrible artifacts (fireflies) and graininess, I see no difference in light strength at all.
P11:
P12:
Miss B ( ) posted Thu, 14 October 2021 at 11:26 PM
RedPhantom posted at 8:12 PM Wed, 13 October 2021 - #4428892
That's one of the goodies I've been waiting for since asking Chuck/nerd during the Poser 12 Webinar if it can be at all possible.ย  This is SO good to see!!!ย  😁
_______________
Butterfly Dezignz
Boni ( ) posted Wed, 20 October 2021 at 4:54 PM
Loving the update.ย  There is an odd problem I am having.ย  In the Purchasing tab, it says that the new purchases are installed as I'd directed ... but nothing shows in the runtimes even after a refresh, I've had to manually install since .703.ย
Boni
adosity ( ) posted Fri, 22 October 2021 at 4:40 PM
Trying to render with Optix:GPU on an RTX 3070 Ti gives nothing but failed renders. After a few seconds of 'Loading render kernals' it briefly flashes what seems to say a COMPILE_ERROR but it doesn't output this to the Log screen so it's difficult to give the full version of the error code. It even fails to render a basic scene consisting of only the Construct and one of the default Poser Superfly Lights sets. No figures or shapes. Odd thing is, it worked once or twice after installing the latest version, even on more complex scenes, but for whatever reason it hasn't since. Clearing the Optix cache in Appdata\Nvidia hasn't changed anything.
Non-Optix GPU renders work fine.
Y-Phil ( ) posted Sat, 23 October 2021 at 4:21 AM
adosity posted at 4:40 PM Fri, 22 October 2021 - #4429266
I have a ticked filed at the supportย  that concerns the weird crashes in RTX mode. That doesn't depend on your card because I've an old RTX2080Ti. It seems that it's deeply hiding in the Cycles engine when it's related to the RTX mode.
I know that they have enrolled a Cycles expert, and they count on his expertise to enhance and correct those hiding bugs...
From what I've obsersed:
* Cycles needs Unimesh
* Some hair props seem to make the RTX render crash, even recent ones
* Sometimes, upscaling or moving the hair prop seem to correct the problem, but it's not always the case
* it looks like sometimes when two objects are intersecting, it crashes, sometimesย  not
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
adosity ( ) posted Sat, 23 October 2021 at 7:51 AM
I'm not at all technically qualified to say, but I doubt the issues are the same. Running the latest Poser version 12.0.703 with Nvidia driver 496.13 it simply fails all Optix renders. I'm starting to doubt it worked before (and that I wasn't just using the normal GPU render), as I now can't get any scene to render in Optix, even with nothing in it other than a simple Ball shape and one light.
Helpfully, today Poser is writing the error to the Log file whereas it didn't yesterday. The part where the render fails is the same each time:
SuperFly: OptiX error OPTIX_ERROR_INTERNAL_COMPILER_ERROR in optixModuleCreateFromPTX(context, &module_options, &pipeline_options, ptx_data.data(), ptx_data.size(), nullptr, 0, &optix_module), line 411
It's always line 411. The same error, other than the line number, appeared in the Blender bug reports early last year: https://developer.blender.org/T73533
It was suggested there to clear the cache from Appdata\Nvidia\OptixCache, but as with the person who added said bug report, it didn't result in any changes here in Poser either. Reinstalling both Poser and the Nvidia drivers has not changed anything either.
Y-Phil ( ) posted Sat, 23 October 2021 at 8:45 AM ยท edited Sat, 23 October 2021 at 8:46 AM
100% Cycles (both are unimesh), rendered using the RTX mode, but I am not using the standard nvidia driver: I'm using only the Studio versions. They come out less often and seem to be more stable. Actually: v472.12
That being said, you have indeed stumbled upon another error compared to me and I think (if it's not already the case) that you should file a ticket...
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
oddbob ( ) posted Sat, 23 October 2021 at 10:09 AM
Having exactly the same issue with a 3090. It started working again briefly after I updated the Nvidia driver as I was a version behind. Now it's back to a flash of a compile error message and a grey screen. Tried reinstalling Poser and driver.
adosity ( ) posted Sun, 24 October 2021 at 9:16 AM
Y-Phil posted at 8:45 AM Sat, 23 October 2021 - #4429294
I installed said Studio driver today, and can confirm Optix renders work fine now.
In fact, I've tried to throw the most complex scenes I can find at it and so far it hasn't had any issue rendering the scenes.
Y-Phil ( ) posted Sun, 24 October 2021 at 9:33 AM
I remember an article I read online, I think that it was 2, maybe 3 years ago concerning the performance of the studio drivers, especially when it comes to games, and the guy stated that the difference was really minimal.
Whatever lol... I don't have enough free time to explore 100% of Poser, so that the online games are for me more like another galaxy than another world... ๐Ÿ˜
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
Afrodite-Ohki ( ) posted Sun, 24 October 2021 at 10:22 AM
I have an RTX 3070 with Studio Drivers. I've had a couple of those crashes - render stops to a gray screen after having just started. None yet with the newest Poser version, but they were rare to begin with, so I can't know for sure.
- - - - - -ย
Feel free to call me Ohki!
ChromeStar ( ) posted Sun, 24 October 2021 at 9:19 PM
I know with the CUDA errors, once the error occurs, all subsequent renders will also fail. But closing Poser and restarting it will reset that. So you could have scenes/frames that render just fine with Optix, but when you try to render them after an error it appears they don't work, because the original error has not been reset yet. The majority of what I'm doing (typically cycles, superfly) works just fine with Optix, a smaller proportion of scenes will fail typically only for a few angles and need to be rendered without Optix.
Y-Phil ( ) posted Mon, 25 October 2021 at 4:47 AM
And I have encountered the following case: an hair prop, which its Cycles-material setup was causing the RTX-crash all of a sudden being rendered without crashing simply because I lowered its render SubD level down to 0....
I know this isn't always the case, but it's better to check it.
๐’ซ๐’ฝ๐“Ž๐“
(ใฃโ—”โ—กโ—”)ใฃ
๐Ÿ‘ฟย Nas 10TB
jadeite123 ( ) posted Sat, 30 October 2021 at 11:46 PM ยท edited Sat, 30 October 2021 at 11:48 PM
I upgraded to Windows11. I've only upgraded the OS and haven't changed Poser 12.0.703 and NVIDIA driver 472.39.
On Windows11, Multi-Device rendering doesn't seem to work properly.
Multiple cards are correctly recognized, but it seems that only one is used in the rendering.
It worked fine on Windows10 before the upgrade.
Curiously, Poser 11.3.818 works fine on Windows11.
Is it a problem in my environment? Or is it a known issue?
jadeite123 ( ) posted Wed, 16 March 2022 at 8:42 AM
jadeite123 posted at 11:46 PM Sat, 30 October 2021 - #4429620
I think I solved that.
Checking "General Preference"-"Render"-"Separate Process" seems to be the cause of the problem in Superfly.
After unchecking it, the Multi-Device rendering works fine on Windows 11.
