Sat, Jan 25, 12:41 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 21 6:51 am)
banner
Subject: Poser symmetry... front to back?
davo ( ) posted Fri, 15 October 2021 at 10:29 AM · edited Fri, 24 January 2025 at 7:33 PM
I know poser has right/left visaversa pose symmetry, but does it have front/back symmetry. For example, if you named body parts fChainseg01 and bChainseg01.  I'd be really stoked if it did.  I also have the same question for Poser 12, not sure if that's something they worked on yet.
Davo
HartyBart ( ) posted Fri, 15 October 2021 at 3:46 PM · edited Fri, 15 October 2021 at 3:50 PM
If you're making a chain with alternating links in it, there's a Poser script by looper-expert Cage: "A script which builds a chain prop along a path defined by positioning marker points". Tested and working in Poser 11.
davo ( ) posted Sat, 16 October 2021 at 11:37 AM
I have a  chain model. My problem is trying to symmetrically mirronr one chains pose to the other chain on the opposite side. I can do this easily with body part names r* and l*, which is right and left symmetrical mirroring, which works fine.  I would like to also accomplish this from front to back as well.
RedPhantom ( ) posted Sat, 16 October 2021 at 4:24 PM
Site Admin
If this is for your own use, maybe a workaround might be to scale the chain on the z axis to -100. It will essentially turn the chain inside out. The normals will be facing the wrong way so you might need to flip them.
primorge ( ) posted Sun, 17 October 2021 at 12:37 AM · edited Sun, 17 October 2021 at 12:41 AM
Example file
https://drive.google.com/file/d/1Q8IKiAA66opGsu_xlxRjkhT7ykpKFPww/view?usp=drivesdk
Front and back is the same as left and right with a chain of bones, just depends on the way it is being viewed. r and l labels will apply symmetry if the front and back actors are named such internally. Note joint order.
primorge ( ) posted Sun, 17 October 2021 at 12:50 AM · edited Sun, 17 October 2021 at 12:56 AM
Of course if you're talking about a chain that is constructed in the shape of, say, a cross or X or an... octopus
? Stumped.
I'm familiar with your work so an octopus chain wouldn't be off the table, in a manner of speaking lol.
If that's the case maybe being more descriptive would have helped.
davo ( ) posted Sun, 17 October 2021 at 12:43 PM
Hi guys,
I completely understand the rigging and and construction of a chain set, that's not a problem at all.  The problem is that currently only right and left side pose symmetry is allowed in poser.  This was to make rigging a figure easier so that the pose symmetry, including joint parameters could be mirrored to the other side of a human figure.  However, when you move away from humans and say into robots, or equipment with cords and chains, having symmetry mirrored from front to back is not possible, or not that I know of.  The closes I've come is rigging a figure right to left then rotating it's base 90 degrees along the y axis. This is okay, but not ideal if  front to back symmetry was just available.
primorge ( ) posted Sun, 17 October 2021 at 2:07 PM · edited Sun, 17 October 2021 at 2:16 PM
davo posted at 12:43 PM Sun, 17 October 2021 - #4429013
Hi guys,
Davo,
Yes I know your rigging skills. I own some of your creature Poser figures. My example isn't a conventional chain rig at all, but a workaround layout for the problem you posted.
"The closes I've come is rigging a figure right to left then rotating it's base 90 degrees along the y axis. This is okay, but not ideal if  front to back symmetry was just available."
Did you even look at my example rig? It's not an ideal solution at all but it's a method or a workaround. Pretty certain it would botch "standard" easy pose to boot. In any case rotating something isn't necessary, symmetry is simply a function of the naming, not which axis it's in during rigging, although joint rotation order is relevant. Poser doesn't care what axis it's in, just the naming as far as I can tell.
I do agree that front to back, or vice versa, symmetry would be nice for the types of figures you mentioned. Not even remotely sure how difficult that would be to implement into Poser code though.
Forgive the illustration typo in my former post reply (should be rLink1, rLink2, etc), was tired from work when I made the demo.
davo ( ) posted Sun, 17 October 2021 at 4:05 PM
Hi primorge,
I did download your file, thank you very much:-).  I was able to get the red balls to be symmetrically posed to the green balls but in a top down view only. If I viewed the figure from the side and moved the green balls up and down, then did a left to right mirror, the red balls went a different direction.  With naming the links rLink1, rLink2 rLink2 and lLink1, etc, then they would have mirrored in all axis correctly.  I believe that poser software uses the r and l prefix as a means to mirror body parts down the Y axis (top to bottom) along the x axis, (side to side)  If they had a f and b prefix (Front and Back), then it could mirror down the y axis (top to bottom) along the z axis, front to back.
D
primorge ( ) posted Sun, 17 October 2021 at 4:15 PM
I see. I didn't catch that. Admittedly I only gave it a cursory test in perspective camera along one axis. Very much an oversite. Can't blame a guy for trying lol. It was an interesting problem though, should have tested further for actual application situations. I'll take another look. I do agree f and b would be nice, sorry my example didn't help.
primorge ( ) posted Sun, 17 October 2021 at 4:38 PM
Looks like you are correct here in rigging and rotating to get the proper result with symmetry front to back. I just tested my example and can see the problem. That's what I get for questioning the practice of an artist that's probably rigged a thousand tentacles, ropes, chains, and tubes ;)
Thanks for teaching me a new trick Davo :)
davo ( ) posted Mon, 18 October 2021 at 10:28 AM
primorge posted at 4:38 PM Sun, 17 October 2021 - #4429022
LOL, no worries :-)  Admittedly I was quite excited to try your rigging because I thought "aha! maybe I missed something" and I'm always open to finding new tidbits of knowledge.  It's refreshing to see responses to threads about technical issues.  I've been using Poser a long time, but have only surface knowledge of a few aspects of it, enough to rig a non-human figure without joint falloff zones and the like.  Ask me questions about lighting, weight mapping, injection morphs, fbm's, texturing and all you'll get is a dumb stare and "uhhhhhh...... weiggggght maaapppinnnng?.  I think Ajax's easypose underground program saved my life cause I could never figure that stuff out on my own.  I miss you Ajax!
primorge ( ) posted Mon, 18 October 2021 at 8:25 PM
Great program, easypose underground. I have it too, very useful for a host of things besides cascading ERC. 👍
davo ( ) posted Tue, 19 October 2021 at 11:12 AM
primorge posted at 8:25 PM Mon, 18 October 2021 - #4429086
Yep, Easypose Underground and philC's Heirarchy Builder are the backbone of my rigging toolbox.
primorge ( ) posted Tue, 19 October 2021 at 2:55 PM · edited Tue, 19 October 2021 at 2:58 PM
I'll confess I've never used the hierarchy method of figure creation, call me a masochist but I enjoy the process of adding bones manually... probably would of saved me a lot of gaaaaahggg! moments with this guy...
an old figure of mine, materials need to be updated to SSS so these renders are rather primitive by current standards. Something I'm planning on getting around to, amongst a bunch of other more contemporary improvements. Anyway its 123 bones, EasyPose, and IK tentacles set up manually. 150 some odd morphs and a various ERC controls. I made this about 7 years ago I guess, I think I can create a vastly superior version now as my knowledge and sculpting/texturing skills have improved along with tech advancements, on my to do list. Still many of the old Poser utilities and methods are indispensable, irreplaceable really. Sadly many are no longer available for new users to utilize, only usable by those who were fortunate enough to get their hands on them back in the day. Not to say I don't think some of the newer Content Tools and methods aren't a godsend.
Just being conversational, as I think some of your work is pretty far out, no impetus to reply...
xUyICmerC8vMYPwp0cEJb4S69SI9hlIkSbaC1XsE.png6ftwqje4KwlYyJMa93r8LNc8ReHoOLGdlILczJr0.jpgFclh1hx8doR08fvd5aNckVaPhdqO84ETodjLf13S.jpg
davo ( ) posted Thu, 21 October 2021 at 10:20 AM
OH WOW!  That is very cool.  I wish I could do organic modeling, I'm used to doing more mechanical/environmental models. Very nice work!
