DAZ|Studio F.A.Q (Last Updated: 2025 Jan 02 6:48 pm)
For Windows the data and Runtime and any folders at the same level of the zip go into the content directory you wish to use (e.g. /Documents/Daz 3D/Studio/My Library/) where they will merge with the matching existing folders. Macs need to do the same, but they can't just drag the folders in as that will replace the existing folders rather than merging with them.
If the zip is set up for Install Manager - freebies and content from other stores rarely are.
Although the My Daz 3d Library is used by default by Install manager the other folder is still there, and is the default for saving and for user files and is recommended for non-Install manager installs (though some content, such as ExP Morph expansions for Victoria 4 etc., does need to go to the same content directory as the base)
Hi there, here is a small tutorial that may help you understand the Daz Studio folder structure more clearly:
Manually installing Daz Studio content
Hope this helps!
I have setup my DAZ Content directory, so that none of it is stored on the C: drive in my private profile. I do this because:
1. If I update or reload Windows, I do not have to worry (as much) about wiping out my content.
2. Is easier to manage directory permissions, do backups, and relocate the Content to another computer.
3. The DAZ content directory can get quite large, which is why I do not recommend storing it on C:. If you run out of room on C:, you might not be able to boot your system. It is a good rule of thumb to keep your data (DAZ, Financial, Personal, Porn, etc.) on a separate drive from the operating system and programs.
Setup your DAZ content directory where YOU think it best belongs, then adjust DS, DIM, and DAZ Central accordingly.
If you are using Windows, the data and Runtime, as well as any folders at the same level of the zip, are extracted and placed in the content directory you want to use where they will blend with the existing files. Macs must do the same, but they cannot just drag the folders in, as this will replace rather than merge the current directories.
Oliver |
During the install process of DAZ Studio, you can see two install targets:
One is DAZ Studio 4 x.xx, which is the folder, that contains the app exe.
the other one is
Studio (at least in my case) which is the folder, that contains your assets. You can set the path, where ever you want on your computer, EXCEPT your DAZ Studio 4.x. folder.
Do NOT install your assets there ! Keep App folder and assets folder separate from each other!
Your assets can go again either into "My Library", "Content" or "My DAZ 3D Library"
I highly recommend 7zip as a unzipping app.
Open your zip file and select and unzipp everything under "content" or "My Library" or that contains "data" "product/Vendor name" and "Runtime" into your asset path.
Done!
I have installed DAZ on my C drive and My DAZ 3d Library on my external drive, E. All of the DAZ content from the DAZ site installs with DIM without any issues. The problem I'm having is that I install content from Renderosity manually into the appropriate folders in My DAZ 3d Library and I can see them there. However none of the Renderosity content appears when I open DAZ. I've clearly overlooked something major, but can't tell what I've missed. This is the third computer I've installed DAZ on, and the only one that I've messed up. Any suggestions to get the items to appear in DAZ?
What I found is that I needed to add a path to the external drive in Content Directory Manager under DAZ Studio Formats. Now DAZ sees the external drive and the manually installed assets from Renderosity. The problem now is that I have two separate My DAZ 3D Library file trees in DAZ: one sees only DIM installed assets and the other sees only manually installed assets.
I would like to have one My DAZ 3d Library that sees both the DIM installations and the manual installations.
If they are in separate places then they have to have separate entries, the only way to consolidate them into one would eb to merge the folders on disc. You could rename the manual folder to something else ("My Daz 3D Library" is just the default name, the name isn't functionally siginificant) and update the setting in Daz Studio, which would at least make it easier to keep track of which folder was which when loading content. You can also use categories and products to hav a single list, but of course that means categorising or setting up products for things that lacked metadata.
I use to be heavily into 3D rendering programs back in the day learning the skills of the trade on Bryce 5 and Poser Pro 6. One of the first things that gave me trouble right away with Daz Studio was the apparently redundant folder tree and me being use to unzipping Figures(Victoria) for Poser and her clothing and material files directly into the runtime folder and that was that. Can someone please tell tell me the correct path to unzip files like this into?
