Poser 12 F.A.Q (Last Updated: 2025 Jan 08 9:20 am)
I have Poser11 installed in its default directory (C:....)( and Poser12 installed on an SSD drive, using the path P:.....
Both are sharing the same runtimes collection (except Poser12's specific one), all on a third path.
Which means: yes: it should work, as long as there is a standard Windows path for the windows system, even if it's a networked one (automatically reconnected at startup)
I can't respond for Mac OS but I'm pretty much convinced that the same rule applies.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
At the college I work at we have a site license for 14 seats of poser 2014. I installed one copy to the first computer and then had the content installed to a NAS Box. This took the most time. After that I just installed the Program to each computer and then copied over the Poser Preference Files to each clone. Every computer used the same Runtime and for student use the NAS was a Read-Only Drive so they could not change the common data. Posedr has no problem with doing this.
Did you connect via Ethernet, Thunderbolt 3 or some other method
Gary
It is all done via Ethernet. The computers were located in 6 different rooms. 8 in a common edit pooly, 3 in 3 audio editing rooms (1 per room), The instructors computer in the TV studio and the last 1 in the Audio control room for the TV studio
Provided the individual PCs are 'licensed' and have correct 'authorisations', keeping a raft of 'external libraries' on other drives, internal, external or NAS, should not be an issue...
I have the 'Poser' core on C: with sundry external libraries on E: , F: and G:. There's a usually-dormant NAS RAID archive, too...
My poser 11 pro is on a Mac 64 GB memory, lots of s storage, RAD5, SSD's nice machine older OS so it covers 32 bit and 64 bit apps
Poser 11 runs a lot of older python scripts I use daily
Want to by a high end Win computer so I can runs scripts that only run on windows or under P12, Render in superfly via the video card, etc
I want to share my content between the two computers. Over 15 years ago I did this where I had a NAS connected to a Mac and a Windows machine at work. CAD system. Back then the drives were slower, then what you can get today.
Anybody doing this or have any advise or things not to do suggestions Plus any comments on speed of reading poser content on a shared drive either by Ethernet or thunderbolt
TIA
Gary
Gary
