Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Shadow catcher doesn’t work in poser 11 SF. In P12 there were issues, but I don’t remember what they were and my poser computer dies so I can’t check. If you render over a background shader rather than a sphere it works fine in the same manner as firefly.
If you want to use Ezdome it has its own shadow catcher that it can setup
RedPhantom posted at 11:29 AM Mon, 7 March 2022 - #4435537
I will take a look at EZDome again. I usually don't mess with any of the settings, so I will check that out.Shadow catcher doesn’t work in poser 11 SF. In P12 there were issues, but I don’t remember what they were and my poser computer dies so I can’t check. If you render over a background shader rather than a sphere it works fine in the same manner as firefly.
Just in case you need some explanations by Snarly himself: see his video.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
And just in case you'd like to use Poser12's background node, you may use a PoserSurface's "Shadow_catch_only" mode on a round ground plane, using the show settings:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
You may check for the actual "official page" here.I am still on Poser 11, and I will check which version of EZDome that I have...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
All I can find is that it says it's build 49, so apparently, I have an older version?
Snarly's website is suspended in the link there, so I don't even know where to get the latest version that will work with Poser 11...
Snarly's Scripts are now hosted by a fellow member, CobraBlade. You can find them here --> Snarly's Scripts
_______________
The last versions for Poser11 and Poser12 are on cobrablade.net, precisely.All I can find is that it says it's build 49, so apparently, I have an older version?
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thank you, Miss B!!!!Snarly's Scripts are now hosted by a fellow member, CobraBlade. You can find them here --> Snarly's Scripts
Since I can't get a shadow in my version of Poser 11, I decided I would have to do some post work to get one in there. I will have to do another render of this without the ezdome and get the shadow on the ground or use one of the planes in the primitive folder.
I changed the pose because I didn't like what her right hand was doing.
I want to use the ground to capture the shadow of my figure, and have it appear to be on the background image in EZDome.
But I can't figure out how to do it. I know I pulled it off once in Poser 8, by ticking the shadow catch only and some other thing I saw someone posted in here years back.
How would I do it in Superfly?
Here is the image I am trying to do that with.
