Fri, Jan 3, 9:58 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Poser 11.3.818 is not rendering at all. Need an older version
RAMWorks ( ) posted Tue, 15 March 2022 at 5:28 PM · edited Tue, 31 December 2024 at 1:21 PM
Hi,
Not sure if it's cool but for what ever reason
Poser 11.3.818
is not rendering at all so not sure what's going on.  I think I ran into this a year or so ago and someone came to my rescue but now I have a fairly new system and so I'm in this loop of trying to get things back up and running and I can't find that older version of Poser that worked for me, I think it was like 11.3.7XX but  can't be sure at this point.
Any help with obtaining a copy?  I have my license so that's not an issue.
Thanks so much
Richard
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
NikKelly ( ) posted Wed, 16 March 2022 at 7:51 PM
What is your PC & graphics set-up ?
If eg NVIDIA GPU, do you need to enable CUDA ?
Can you get a render using CPU only ??
IIRC, I could not get my system working well with GPU cards' default driver, as 'optimised' for gaming. I had to down-load the 'general purpose' version...
RAMWorks ( ) posted Wed, 16 March 2022 at 9:52 PM
I have an NIVIDIA card, I just assumed that CUDA was enabled by default.  I did find a SLIGHTLY older version of Poser, still in the 11.3 range but that seems to have done the trick.  Where would I check to see if CUDA is enabled?
Thank you!
My Store is HERE
NikKelly ( ) posted Thu, 17 March 2022 at 7:36 AM
Nvidia control panel, 3D settings, manage 3D settings, global settings, about ten lines down: CUDA-GPUs. My setting is ALL but, IIRC, began as app-specific...
RAMWorks ( ) posted Thu, 17 March 2022 at 9:11 AM
It's set to all.  Weird that Poser shows up in the Add list as Poser 7!
My Store is HERE
