Sat, Jan 4, 5:02 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: SceneFixer, Poser12 version
Y-Phil ( ) posted Thu, 21 April 2022 at 3:36 PM · edited Sat, 04 January 2025 at 5:01 PM
Hi
I had an email exchange with SnarlyGrtibbly. He's kind enough to release to public domain its  Scenefixer.
So, I have a first version that seems stable.
Nothing has fundamentally changed, I have added the possibility to add an area light.
I have fixed some inconsistencies due to Python3, for example some variable names are now Python keywords.
This has been tested on Windows 10. I have no access to a Mac, so that I can't check.
I have not experienced any crash, but it is better to be careful and save before.
You can download the actual version for this link.
The script is probably going to evolve
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Miss B ( ) posted Thu, 21 April 2022 at 6:28 PM
Thank you muchly.  😁
_______________
Butterfly Dezignz
Rhia474 ( ) posted Thu, 21 April 2022 at 6:50 PM
Oh boy, I missed this one for clothes SO much! Off to play and thank you for your and Snarly's generosity and work!
hborre ( ) posted Thu, 21 April 2022 at 9:24 PM
The script works flawlessly.  Thank you kindly for putting in the effort and contributing your talents to the community.  It is very much appreciated.
Y-Phil ( ) posted Fri, 22 April 2022 at 1:53 AM
Thank you all: it's a pleasure for me to help 😄
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
RoseHawk ( ) posted Fri, 22 April 2022 at 8:48 PM
First, thank you for your work in converting this scrip.
When I use the Dials option and click "None" I get a error message, (see screen grab).
The "All" "Inverse" "Reset" buttons work as expected. I don't know what the "XYZ" should do but it clears all the highlighted items.
I have not yet tried everything that the scrip can do but so far this is the only thing that has given me an error.
Improvement means change. Change need not mean improvement.
I use Poser 12.0.757, 11.3 and or 2014, on Win10 64bit.
Y-Phil ( ) posted Sat, 23 April 2022 at 12:04 PM · edited Sat, 23 April 2022 at 12:04 PM
Using Poser, I like to keep my lights organized by groups.
Most of the time, they are arranged like this:
That's the reason why, sometimes, I need to add a grouping object, which then must be renamed and parented somewhere else.
I have corrected the problem @RoseHawk encountered and I have re-organized the "Add  light" part so that we can now add a group right under the currently selected actor.
Just check "Location is relative to...", select the right actor and:
The updated version has a new version: V2.01. It can be downloaded here.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
RoseHawk ( ) posted Sat, 23 April 2022 at 5:12 PM
Thank you for the update :)
All working now.
cedub53 ( ) posted Sat, 28 May 2022 at 11:04 AM
Hi
Have not tested extensively, but seems to be working okay on Mac (M1)
Y-Phil ( ) posted Sat, 28 May 2022 at 11:43 AM · edited Sat, 28 May 2022 at 11:43 AM
cedub53 posted at 11:04 AM Sat, 28 May 2022 - #4439265
Hi
Good news, thank you for the feedback 😄
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
