Poser 12 F.A.Q (Last Updated: 2025 Jan 20 1:09 pm)
Those render setting are not much different from mine. I took a look at the transmap for Alanis hair and modified it with a darker curve in Photoshop. This does seem to make the strand ends have more definition. I'll post a render in a bit
Here is what I got. I used my "Construct 1 Big" light set. A couple of things: My light set is probably a bit too bright. That's OK we can fix things later with Poser 12's Post FX. I turned down the exposure to .8 and that seems to give a good balance between bright skin and brighter hair. Another thing that helps is exporting as an uncompressed file format from Poser. Poser's jpg algorithm borks fine detail in the render.
Ha. Okay, learning things big time here that I wish were available for people who do this the first time. That thing about jpgs for instance--is that a bug? Will it be fixed? (eager minds want to know)...
Doing some renders now without the progressive refinement--yes, I took one of your render settings you kindly posted a while ago as my base.
And ...that transmap made that render you just posted above much better. I'll post my images once finished but I think you got the culprit nailed down with that hair specifically. My renders are always unedited and no-postwork, because I like to make sure a Poser render is showing what Poser is capable of.
about Poser's jpg export: Even on the highest setting it messes with fine detail. That's OK with me because making jpg files is not what Poser is made for. A photo editor program is going to be miles better than Poser for making a clean jpg file. I just consider it a courtesy that Poser makes a jpg for those quick renders that aren't critical.
Okay, first results are with unadjusted transmaps, four setups previously mentioned. No pose or material was changed on model or hair between the 4, only light setups. You will notice my renders are not nearly as strongly lit. Also note in all cases the extremely poorly defined flyaway ends.
1. HDRI on background as defined by ghostship in their tutorial on poserfsoftware, used as a light source.
(ignore that crack on figure, forgot to convert to unimesh and subdivide model, fixed in later renders)
2. HDRI on background as provided by bastep's free shader, used as light source. Used exact same HDRI:
3. Sphere and infinite background from Afrodite-Ohki's LevelUp Superfly package available here; no light except the sphere material.
4. EZ Dome, using sun light properly placed based on IBL on dome:
Next post will include some variations based on the transmap of the hair adjusted by the curve shown below and replaced on all hair materials.
All right. I think we got it; transmaps can make or break a hair regardless of lighting, render settings or shaders.
1. Look at those flyaway ends!
2.
3.
4.
So: in conclusion--whatever you do, take a look at the provided transmap and if after a testrender, it looks mushy like mine did, do ahead and adjust it. Older hairs tend to have, apparently, not only burned in highlights but unnecessarily bright transmaps that may muddle the render of fine ends.
@ghostship2: I sincerely thank you for going through this with me and showing me several things that will help me being better at this!
Thank you BOTH for these informations. I've an old hair prop that I'd like to use but the transmap is... "sorry-no-valid-polite-English-translation-available"...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
And when it comes to save a pic file with Poser: I've never used any other option than PNG. The only moment I'm creating a JPG is with Photoshop, as a final thingie to publish online.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I agree, as I always want a transparent background which, of course, I have to select in P12, but I've always found PNG to give the sharpest images.And when it comes to save a pic file with Poser: I've never used any other option than PNG. The only moment I'm creating a JPG is with Photoshop, as a final thingie to publish online.
_______________
Late to the party but that is nothing unusual. My Poser time and expenditure is much reduced so far in 2022 but I just had to buy this and have a play.
Ali's HR-153 Hair
Ali's HR-230 Hair
Taiana Hair Afrodite-Ohki
This is fun, for someone like me, with limited skills, to get results like this with just a few clicks is not just amazing but magical.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Gorgeous pictures!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hornet3d posted at 4:49 AM Wed, 27 April 2022 - #4437790Thank you, with this hair shader it is hard not to get a good result.Late to the party but that is nothing unusual. My Poser time and expenditure is much reduced so far in 2022 but I just had to buy this and have a play.
Gorgeous pictures!
Playing with old-timer Pauline and her Gwenith hair. Used Merchant Resource Hair with GSHSS (roughness reduced to .6 was only other change) and used Ghostship2 lights. Amy morph with Jackie texture (used Texture Transformer, of course). I love using the streaked hair tex with this. I had to reduce the UV width to .33 to make it look more natural (as natural as bleached hair can look).
Old lady hobbyist.
All visual art or fiction is "playing with dolls."
Beautiful, wow
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
VedaDalsette posted at 11:29 AM Sat, 30 April 2022 - #4437923I agree.Playing with old-timer Pauline and her Gwenith hair. Used Merchant Resource Hair with GSHSS (roughness reduced to .6 was only other change) and used Ghostship2 lights. Amy morph with Jackie texture (used Texture Transformer, of course). I love using the streaked hair tex with this. I had to reduce the UV width to .33 to make it look more natural (as natural as bleached hair can look).
Beautiful, wow
_______________
The cast shadow is always on by default with very little chance of automatically turning off. There appears to be some self-glowing going on, possibly the skin shader. The ear on the left doesn't look right to me, too bright in my opinion. A screencap of the skin shader might reveal what's going on.
ghostship2 posted at 3:30 PM Sat, 30 April 2022 - #4437934
ghostship2, you're right! And I see the difference. Her hair isn't glowing now. I must stop turning off cast shadows!@VedaDalsette Somehow you turned off cast shadows on that hair piece. It looks off to me.
hborre, it's not her skin glowing. It was her hair! Below is her Pauline head (Amy morph). Pretty lame tame. It was my fault for turning off cast shadows. (I'm so used to doing it for Master Skull Cap.)
Oh, and thanks, Y-Phil and Miss B!
Old lady hobbyist.
Thank you, I really do appreciate your comment.@hornet3d these look great!
Still have fun with the shaders . Amphitrite, goddess of the sea.
Hair from OOT, character Tempesta.
Woah... gorgeous picture 😍
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
TheAnimaGemini posted at 6:05 AM Sun, 1 May 2022 - #4437960Thank you 😊Still have fun with the shaders . Amphitrite, goddess of the sea.
― Marcus Aurelius,
hborre posted at 6:41 AM Sun, 1 May 2022 - #4437963
Actually not much. I add just some contrast. The soft blur comes from DOF. I had it at 5.6 and high key light with colors.Very nice. The lighting is superb. Any post work to get that delicate, soft look?
Thank you ☺
― Marcus Aurelius,
Thank you 🤗😊@TheAnimaGemini that is beautiful!
― Marcus Aurelius,
Rhia474 posted at 12:09 PM Sun, 1 May 2022 - #4437981
Thank you so much ☺🤗☺Whoa. Learning. That is such a delicate, beautiful combination of lights and camera along with the colors. Thank you for sharing!!
The background is just a simple backdrop, pure white. Lights are high key lights. 3 of them. 1 left 1 right and one on top 1 of them colored for more accent.
I scale up the Area lights very big for very subtile shadows.
― Marcus Aurelius,
I couldn't help but test one of the most beautiful hairs I've had: Danae's Bliss Vision Hair, It dates: 2004, and it was for vic3. Thanks to Ghostship's Hair system: wow...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
ghostship2 posted at 11:04 PM Sun, 1 May 2022 - #4437994
This is thanks to you, so thank you twicelooks great!
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Indeed: and I'm the first astonished...@Y-Phil
Agree, Bliss hair is still amazing.
Great render and the hair are looking good with the new shader
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I was finally able to get this. I see it has for horizontal, vertical, or a combination. Is there any way to use it for maps where the hair goes every which way without resorting to using the texture maps that it comes with that have horrible baked-in highlights?
@RedPhantom I agree with hborre. Some hair pieces need those specialty texture maps (radial orientation). I'm crap at painting hair otherwise I might provide a couple. The main culprit is older hair pieces. Vendors have figured out how to make hair so they don't have to re-invent the wheel with each texture map.
Yeah, these are older hair. I should just abandon them, but there are a few styles I like that I haven't replaced yet.
If the radial hair is just on a skull cap, with some other layers over it that are horizontal or vertical, at least sometimes you can just use that original map and it's ok. Give it a try. I've been quite pleased with the results. And I thought I had good shaders before just based on things we discussed on the forum here, but these are better.
Unfortunately, the cap shows as they're updos or the hair is pulled back.
I look forward to seeing what you two come up with, as I have the Alanis Hair, and even though I haven't used it much lately because I don't use V4 much lately, I certainly would be interested as I can use it with La Femme and the V4 Skull Fit.
_______________
Butterfly Dezignz
