Poser 12 F.A.Q (Last Updated: 2025 Jan 08 5:19 pm)
You might try adjusting the center or the endpoint of the belly ring
OK try this:
Again zero figure... Enter the Fitting Room/New session.... Select your prop & figure, do nothing else just create a new figure. In the dialogues select nothing NO regroup No morphs.... Just an empty figure ..... Now back in the Pose Tab rename New Figure to Bellybutton ring(whatever) select that figure's abdomen...Menu/Object/ replace body part with prop/ Select the original bellybutton ring and hit enter... test by conforming to figure and if satisfactory delete the new prop, save figure to library...
Y'all have a great day.
OK try this:
Again zero figure... Enter the Fitting Room/New session.... Select your prop & figure, do nothing else just create a new figure. In the dialogues select nothing NO regroup No morphs.... Just an empty figure ..... Now back in the Pose Tab rename New Figure to Bellybutton ring(whatever) select that figure's abdomen...Menu/Object/ replace body part with prop/ Select the original bellybutton ring and hit enter... test by conforming to figure and if satisfactory delete the new prop(if its still there), save figure to library...
Sorry for double post too late to edit I guess...
I exported a belly ring prop from Daz (as an obj) into Poser 12 so I could use it on V4. I positioned the ring right where it needed to be in her naval, parented it to her abdomen and saved it as a prop. it loads back in place just fine, but whenever I pose V4, the ring moves from her naval. Not a lot, but enough that I have to adjust it each time to get it back where it's supposed to.
Is there a way to make where I parent the prop more precise than just her generic abdomen? Thanks!
(I also tried parenting to her hip, but that was even worse.)
