Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 08 11:18 am)
Why do you have a Scatter node in the lower right-hand corner of your Material Room screencap? You should be connecting a Diffuse map to that SeparateRGB node. That might be causing the added glossiness you're seeing. Personally, the Scatter Distance values are way too high but they work for you without causing self-illumination then leave them the way they are.
OK, I'll give that a try! Thanks folks!
---Wolff On The Prowl---
OK, well that killed the shine but not sure how to set up the blend as now I have that line again.
Better but not perfect
On that first image with the Color_Math node, why do you have a black chip in value2 on a multiply function? That should be white for the function to work correctly. White, imagine it being 1, multiplied by black, the equivalent to 0, will result as a final result of 0, no effect. And in your second image, the math function is division, contrary to what Nerd suggested. Did you try his suggestion and found that it didn't work? There is no elaboration in your responding posts. If everything hasn't worked to your satisfaction up to now, have you tried darkening the Specular chip on the PhysicalSurface? I also noted that your emission chip is not completely black although there isn't any emission strength applied to it. I would adjust it just to make certain that that channel isn't leaking light.
I think it either came in that way or I tried it with both chips white and it wasn't good. I can't remember off hand!
So I guess this is as good as it will get. I did simplify the set up a bit more and removed the scatter nodes and also copied over the Math node to the shaft and testes BUT did have to reduce the specular for both to make it work out correctly! I still see a line where the trans area and the shaft edges meet but I don't know how to resolve that.
I don't know if it has an impact or not, but if I remember correctly, Bagginsbilll one day stated that on bump and trans maps, gamma should be set to 1.0, and they shouldn't have any filtering applied, to be sure that the datas of those "pictures" arrive without any modification.
And that's something I'm doing each time, now.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
OK, I'll check that out. I'm sort of redoing a bunch of settings so I'll double check those. Thanks so much!
Here is my setup and a render. In Firefly it renders fine but using the Physical Root node I'm not able to get a good blend between the pubic patch and the shaft of L'Homme's genitals. If I turn down the specular or I darken the specular then I get a divided line. I want the shaft to have some specular gloss that matches the skin I've got set up. I could turn all the specular off but then it looks dull and not right when compared to the rest of L'Homme's body.
Thanks for any help and PS, I don't want to creating 10,0000 nodes to rectify this, simple as possible! LOL
My Store is HERE
My Freebies are HERE
