Poser 12 F.A.Q (Last Updated: 2025 Jan 08 5:19 pm)
try this setup. the fac of the first mixclosure controls the strength of the transparency. Either plug a transparency map into it or reduce the number to increase the transparency
Glad I could help
From time to time: check the bitmap's gamma: it should be 1.0 not the default 2.2, this is for all bump and Transparency bitmaps.Glad I could help
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
I'm still very much in the dark about using cycles in Superfly, so I've only been able to slightly tweak a few of the given textures I've bought. One thing I'm trying to do is add a slight transparency to a texture, in this case a silk satin texture. I just have no idea where to attach the node. Any help would be greatly appreciated!
