Mon, Dec 23, 8:11 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Dec 22 9:02 pm)
Subject: Adding transparent BSDF to texture?
DocMatter ( ) posted Thu, 02 June 2022 at 10:50 AM · edited Mon, 23 December 2024 at 7:54 AM
I'm still very much in the dark about using cycles in Superfly, so I've only been able to slightly tweak a few of the given textures I've bought.  One thing I'm trying to do is add a slight transparency to a texture, in this case a silk satin texture.  I just have no idea where to attach the node.  Any help would be greatly appreciated!
RedPhantom ( ) posted Thu, 02 June 2022 at 11:39 AM
Site Admin Online Now!
try this setup. the fac of the first mixclosure controls the strength of the transparency. Either plug a transparency map into it or reduce the number to increase the transparency
DocMatter ( ) posted Thu, 02 June 2022 at 3:23 PM
That did the trick.  Thanks so much!
RedPhantom ( ) posted Thu, 02 June 2022 at 4:17 PM
Glad I could help
Y-Phil ( ) posted Thu, 02 June 2022 at 4:54 PM
Online Now!
RedPhantom posted at 4:17 PM Thu, 2 June 2022 - #4439489
Glad I could help
From time to time: check the bitmap's gamma: it should be 1.0 not the default 2.2, this is for all bump and Transparency bitmaps.
In my case, I even take the time to set their filter to None.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
