Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
πΏΒ Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
πΏΒ Nas 10TB
πΏΒ Poser 13 and soon 14Β β€οΈ
La Femme as the holographic AI Cortana
Poser 12, in feet.Β Β
OSes:Β Win7Prox64, Win7Ultx64
Well done Seach!ΒLa Femme as the holographic AI Cortana
_______________
Thank you, @Miss B !Β :D
Material update -and a few new meshes, such as the apsynthe "I dream of Jeanie" bottle- of a scene set up to test and experiment with BB's material ideas for metals, glass, volumetric liquids, and light-scattering candle wax.Β Rendered at 4K in P12 Superfly.Β At 4K, you can read the embroidered mithril script on the hems of her shawl and skirt!Β :D
As often: an exercise that ended up in a beautiful picture β€
No lighting involved, and I had to reduce slightly the "power" of the HDRi.
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Nas 10TB
The candles are from 3dcheaoskate and adapted for superfly. The flames and 5 point lights set at 0.2% light the scene
Very well done!Β I love the atmosphere
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Nas 10TB
Thank you both so much
WHOA. Ok, color me impressed.In the liquor cabinet of Cafe' L'Homme:
- - - - - -Β
Feel free to call me Ohki!
Seeing how creative some users are rendering their candle scenes, I decided to put something together for Superfly.Β I grouped 3-types of candles together, a tealight, a votive, and a pillar, on a desktop.Β I fashioned an aluminum cup out of an open-end pipe primitive and inserted the tealight candle into it.Β Then all the original shaders were converted to Cycles PBR.Β This included the self-illuminating flames.Β To help with the candlelight, I added the accompanying point lights, changed them for Blackbody emission, and scaled each to their corresponding flame.Β An additional low-intensity mesh area light was placed above the scene as a fill light.Β The Faerie is Miki 4.
The flames are really impressive, especially with the dark area in their base center, and the overall is splendid.
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Nas 10TB
A scene made for @bagginsbill's tutorial thread on underwater godrays:
I've just discovered the wonders of taking the HDR .exr raw render from the RenderCache folder and color-correcting it in photoshop. Super simple way to make up for our lack of filmic colorspace.
Tutorial for it is pending approval and should be up soon :)
- - - - - -Β
Playing around with Lafemme and the morph brush
The result is... wow β€
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Nas 10TB
Here is my latest render, as usual based on an older scene that I tweaked the heck out of, because apparently that's how I roll and/or learn. The version in my gallery is topless, but I thought for the forums she might as well dress up a little. :-)
Two things of note here: first and foremost, for the longest time I've been struggling with pure Cycles eye shading. In principle it should be easy, just use a Glass BSDF with default IOR for the cornea to get a plausible lens refraction and reflection. But my irises always ended up way too dark, pretty much black. So last night I decided to finally debug the problem properly. It was actually a whole mess of things I got wrong:
- Refractive caustics need to be turned on in the render settings. Sometimes I remember, sometimes I forget.
- The default color for the Glass BSDF node is a very light gray. It needs to be set to a perfect white for a fully transparent lens.
- I had a bump map on the iris that was way too strong. Antonia's eyes are not ready for a closeup, anyway, so no point in using the bump map, at all.
- With all these things fixed, there is still some loss of brightness due to surface reflections, so the iris texture needs to be quite a bit brighter than one wants it to appear in the render. I found that an HSV node with the value set to 2 does a good job, but YMMV.
Number two is the displacement map on the beanie. I'm using a weave texture here that at first I simply plugged into the normal, but that didn't look that great, especially in closeup. So then I plugged it into the displacement, but of course I had to crank the subdivision all the way up to get a decent effect. Totally worth it, though, I think.
I routinely use multiply only on the displacement math node and use lower values unless you really need to exaggerate the displacement.Β I've only had to go with 1 subdivision on V4 for skin textures.Β I have started experimenting with the glass node on the cornea, and that IOR value will need to be changed to 1.33 to be close to accurate.
hborre posted at 11:01 PM Sun, 12 June 2022 - #4439914
Ah yes, thanks, I misremembered that.I have started experimenting with the glass node on the cornea, and that IOR value will need to be changed to 1.33 to be close to accurate.
And yes, I should probably just switch to a PrincipledBSDF for the cornea.
I decided to try a "physically correct" simulation of a mirror in Cycles nodes: two parallel planes, the back one with a fully reflective shader like this
and the front one with a glass shader that has a very faint green tint, almost white. I think the result looks quite nice:
One could also use a very shallow glass box with a separate reflective material on the back. I think this method could also be useful for simulating various forms of blemishes and damage that happens in real mirrors, but haven't tried much in that direction yet. I think it's important not to have a perfect reflection, or the mirror will end up looking like a portal into a parallel dimension.
Just poked my nose in here. Love the lace and eye surface textures! Thanks.
W11,Intel i9-14900KF @ 3.20GHz, 64.0 GB RAM, 64-bit, GeForce GTX 4070 Ti SUPER, 16GB.Β
Old lady hobbyist.Β All visual art or fiction is "playing with dolls."
VISIT MY ALBUMSFOR COMICS: https://www.renderosity.com/users/VedaDalsette/gallery/albums
You can also get to my comics from my book website: https://www.vdbooks.com.
You people are too kind to me - thank you, I'm so glad you like my newest gal <3
And as usual, some gorgeous renders here!
- - - - - -Β
π«π½ππ
(γ£ββ‘β)γ£
πΏΒ Nas 10TB
An old scene I made for the release of P9/Pro2012, to demonstrate the possibility of lightcasting (meshlights) in Firefly IDL.Β After a few material updates, this is a P12 Superfly render at 4K resolution.
sailing through Lothlorien
The Grey Havens from Lord of the Rings
Grey Havens
An elvish grey ship underway at night
Grey Ship
