Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 10:25 am)
Thank you!! I much appreciate itEasiest workaround: Get Poser 11 while it is on sale.
Otherwise:
Switch the library from FLASH to AIR.
https://www.posersoftware.com/article/499/how-to-fix-your-runtime-now-that-adobe-flash-has-reached-end-of-life
That's how I run my PP 2014 on Windows 10.
https://www.darkelegance.co.uk/
There is a Flash version that will enable the old Library in Poser Pro 2012 and Poser Pro 2014 , actually Poser 9 and 10 if you prefer using it instead of the external Air version
Tested and running on my Win 10 21h2 version. Make sure to remove any older flash versions, actually they should be already off on most systems . Working flash version is V.11.2.202.235
you can use the Working flash version I uploaded and give it a shot ... if it works for you you might be doing a happy dance. Make sure to disable automatic updates after Install, you will be asked !
I am still trying to figure out a method like the solution above for "Reality" to be working again ! The above original Flash version fixes many older apps that depend on Flash but it does not work for Reality and I have not figured out why that is, until now .
As for of those that run Poser 11.2 it sure is an option having the library without Flash but since Bondware broke the Python engine for most Pythons on there update after the original release of the Smith micro versions it might be still good having a working PP 2014 or 2012, at least for the ones who depend on Pythons or are in Possession of older bought packages that have python helpers in there setups.
Anyway if someone might have a good solution based on the above method using older Flash versions making also Reality work again it sure would be a great thing to have.
Thanks for the link Cascade777.
I don't have any need for Flash in Poser (anymore), but I loved playing Flash games.
I currently use Ruffle and BlueMaxima's Flashpoint for my old animations and games which stopped working on Windows 10.
I wonder if Ruffle would work with Poser, but as I said, already use the Air library. (And Poser 11)
Still good to have options!
So today, after many years of it gathering dust...I decided to open my poser. 2012.
To find apparently the library doesnt work anymore? Is there a work around?
Commission Closed till 2025
