Fri, Jan 10, 5:25 PM CST
Forum Moderators: Staff
Subject: Poser regroups obj on its own
anniemation ( ) posted Thu, 14 July 2022 at 10:30 PM · edited Fri, 10 January 2025 at 4:43 PM
Online Now!
I'm trying to rig a figure - I'm at the most difficult part - the toes.  Everytime I try and group them the rest of the grouping gets messed up.  I'm being super careful to make sure no polys are grabbed by mistake.
Please help!
jennblake ( ) posted Fri, 15 July 2022 at 8:16 AM
jennblake has moved this thread from the Vendors Support forum to the Poser Technical forum as of Friday, July 15, 2022 8:16 am
primorge ( ) posted Fri, 15 July 2022 at 2:20 PM
anniemation posted at 10:30 PM Thu, 14 July 2022 - #2972194
Please help!
Are all the toes meant to be one group or actor or are you going to rig each individual toe?
primorge ( ) posted Fri, 15 July 2022 at 2:46 PM · edited Fri, 15 July 2022 at 2:52 PM
...if you are rigging each individual toe than the toe groups need to have a row of polys between each toe belonging to the foot actor. Otherwise there will be mesh breaks because Poser is confused by child actor having more than one parent. Each child (a toe) can only have one parent, the foot. Hence the row of polygons that separates the children and belongs to the parent foot.
Be careful with how you name your groups. Try to name left and right with lower case l and r and try to avoid punctuation and spaces. Using spaces may cause Poser to regroup. So rToe1 would be ok. Right toe 1 probably not. Obviously this is internal names. External names can be anything you wish. Alot of this is ancient Poser stuff but is still relevant and is standard practice.
Otherwise if it's just having poly selection difficulty you might try grouping it externally in a more precise modeling software. If you are using the grouping tool and selecting in wireframe display it will generally select polys that are facing away from the camera on the mesh too.
anniemation ( ) posted Fri, 15 July 2022 at 5:45 PM · edited Fri, 15 July 2022 at 5:45 PM
Online Now!
What was happening is I would re group a toe go back out to main room and the rest of the groups were completely off.  I finally got it all rigged in Auto Group Editor.
