Tue, Jan 21, 11:23 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Jan 20 8:00 pm)
Subject: Rendering With No Background After You've Imported A Background...?
twelvefield ( ) posted Mon, 18 July 2022 at 8:22 PM · edited Tue, 21 January 2025 at 11:15 PM
Maybe I'm missing something, but I can't figure this on my own.  I want to render a model with a transparent background, but I have imported an image as a background.
I know that I can turn the GROUND prop visibility off and set Superfly to render a Transparent Background, and the result is a .PNG with a transparent alpha layer in Photoshop: works perfect if there is no background image.
For some of my models, I've been scanning in my own artwork to use as a reference.  I put that image in the background and then I can line up the Poser model to make it match.  However, once I import a background image, I can't find a way to "unimport" it to be rid of it.  I've tried replacing the image with a transparent .PNG, but that isn't working.  My current workaround is to import a blank grey background, which is fairly easy to eliminate in Photoshop.  It would be more elegant to not have to do that, though.  The background isn't a prop, so it can't be made transparent... right?  Is there an easy fix for this?
NikKelly ( ) posted Mon, 18 July 2022 at 8:48 PM
I may have misunderstood question but, IIRC, GROUND has two materials, one for the floor, other for sky-dome...
RedPhantom ( ) posted Mon, 18 July 2022 at 9:32 PM
Site Admin
go to the material room. choose the background as the object. Find the BG Color node and plug that in the color spot
DCArt ( ) posted Tue, 19 July 2022 at 12:06 PM
In Poser menu, choose Display > Clear Background Picture
RobZhena ( ) posted Sat, 23 July 2022 at 4:49 PM
I often put a background picture on a 1-sided square prop. Of course, that's easy to do in Poser 11 with the simple tab.
