Thu, Dec 12, 7:08 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Nov 29 11:16 am)
Subject: Rendering time
Wilks ( ) posted Sun, 24 July 2022 at 3:43 AM · edited Wed, 11 December 2024 at 3:19 PM
Hi guys.
Could someone help me?
When I do rendering I can not see the rendering time.I mean the exact render "number"(it could be seconds) when the render finish each frame.
As you can see on the picture nothing shows the rendering time.Usually there is it.
What sould I do to fix this?
RedPhantom ( ) posted Sun, 24 July 2022 at 6:13 AM
Site Admin Online Now!
I had that problem for a while but then it fixed itself. I'm not sure what I did. I didn't make any changes to Poser but was working on removing bloatware.
Y-Phil ( ) posted Sun, 24 July 2022 at 8:45 AM
It looks like your last rendering lasted 31 seconds. I haven't ever seen the duration, only when it started and when it stopped.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Mac Mini M2, Sonoma 14.6.1, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Richard60 ( ) posted Sun, 24 July 2022 at 9:28 AM · edited Sun, 24 July 2022 at 9:29 AM
You are missing several lines and I am not sure why. One thing I learned long ago was to never install Poser in the C:Programs folder.  Now I install it to a Drive E:Poser folder where I have all my old versions.  When a new version is ready I just rename the current folder from Poser 12 to ZxxxPoser 12 where the xxx is the version inside the folder.  And then run the installer which will create a new Poser 12 folder.  That way it is a clean install every time and I can go back and run a prior version to see if they have fixed any problems I had or in your case if it has a new problem.
jadeite123 ( ) posted Sun, 24 July 2022 at 9:56 AM · edited Sun, 24 July 2022 at 9:56 AM
Online Now!
I have seen a similar problem on Poser12/Windows 11. Please check the General Preference.
These are the results of the CPU rendering, but the behavior is the same for GPU rendering.
Y-Phil ( ) posted Sun, 24 July 2022 at 3:05 PM
I confirm: it the render is not in a separate process, Poser will tell you how many seconds it took, but during a progressive refinement render, you'll get a weird effect that disappears once it's finished or canceled:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Wilks ( ) posted Sun, 24 July 2022 at 3:32 PM
jadeite123 posted at 9:56 AM Sun, 24 July 2022 - #4441758
Thank you.
Now I fix the "Separate process" and I can see the "rendering time".
And I thank everyone for the help.
