Poser 12 F.A.Q (Last Updated: 2025 Jan 08 5:19 pm)
I had that problem for a while but then it fixed itself. I'm not sure what I did. I didn't make any changes to Poser but was working on removing bloatware.
It looks like your last rendering lasted 31 seconds. I haven't ever seen the duration, only when it started and when it stopped.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
You are missing several lines and I am not sure why. One thing I learned long ago was to never install Poser in the C:Programs folder. Now I install it to a Drive E:Poser folder where I have all my old versions. When a new version is ready I just rename the current folder from Poser 12 to ZxxxPoser 12 where the xxx is the version inside the folder. And then run the installer which will create a new Poser 12 folder. That way it is a clean install every time and I can go back and run a prior version to see if they have fixed any problems I had or in your case if it has a new problem.
I confirm: it the render is not in a separate process, Poser will tell you how many seconds it took, but during a progressive refinement render, you'll get a weird effect that disappears once it's finished or canceled:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
I have seen a similar problem on Poser12/Windows 11. Please check the General Preference.
These are the results of the CPU rendering, but the behavior is the same for GPU rendering.
Thank you.
Now I fix the "Separate process" and I can see the "rendering time".
And I thank everyone for the help.
Hi guys.
Could someone help me?
When I do rendering I can not see the rendering time.I mean the exact render "number"(it could be seconds) when the render finish each frame.
As you can see on the picture nothing shows the rendering time.Usually there is it.
What sould I do to fix this?
Thank you for your helping.
