Sun, Feb 16, 3:16 PM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2025 Feb 03 7:20 pm)
Subject: Poser 12.0.1029
tim ( ) posted Thu, 25 August 2022 at 10:10 AM · edited Sat, 15 February 2025 at 9:57 PM
Site Admin
Poser 12.0.1029 for Windows is now available for download at: https://www.posersoftware.com/downloads
Article & Newsletter announcement coming soon.
Miss B ( ) posted Thu, 25 August 2022 at 10:44 AM
Thank You!  Thank You!!  Thank You!!!  😁
_______________
Butterfly Dezignz
Y-Phil ( ) posted Thu, 25 August 2022 at 2:15 PM
Woohoo 😄
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
jarek2001 ( ) posted Thu, 25 August 2022 at 2:25 PM
Finally!
VedaDalsette ( ) posted Thu, 25 August 2022 at 7:47 PM
Just got it! Merci beaucoup.
Old lady hobbyist. All visual art or fiction is "playing with dolls."
VISIT MY ALBUMSFOR COMICS: https://www.renderosity.com/users/VedaDalsette/gallery/albums
You can also get to my comics from my book website: https://www.vdbooks.com.
Rhia474 ( ) posted Fri, 26 August 2022 at 9:18 PM · edited Fri, 26 August 2022 at 9:18 PM
'Material Room: Deleting last node no longer leads to a crash. #1242, #957
Material Room: Default custom gamma for known PBR image map types now set to 1.0. #1354, #1359'
THANK YOU!!!!
prixat ( ) posted Sat, 27 August 2022 at 3:01 AM
Is this a known problem?
Selecting optix makes the trainers black/textureless. Both CPU and non-optix GPU keep the correct textures.
These are the trainers that came with the default content.
regards
prixat
AcePyx ( ) posted Sat, 27 August 2022 at 7:37 AM
The patch notes appear to detail considerably less than your announcement mail. Is there a comprehensive changes list anywhere please Tim?
Y-Phil ( ) posted Sat, 27 August 2022 at 8:46 AM
prixat posted at 3:01 AM Sat, 27 August 2022 - #4443407
Trainers? default content? the only trainers I've found came with the EvoGirls.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
prixat ( ) posted Sat, 27 August 2022 at 9:36 AM
They're called Fads Sneakers.
Quick check, is it OK to merge this latest content into my main runtime and allow it to overwrite the old La Femme etc.?
regards
prixat
Y-Phil ( ) posted Sun, 28 August 2022 at 9:54 AM · edited Sun, 28 August 2022 at 9:54 AM
prixat posted at 9:36 AM Sat, 27 August 2022 - #4443415
That's not a bug, at least not from a technical point of view, I find this a really huge sale bug: by default, those fads have material that is thought only for Firefly, as they have Amient _occlusion nodes, which are not supported by the RTX mode. I have an old RTX2080Ti and the effect is the same.
Most of the time I rebuilt the textures, especially for the skin and for the cloths.  Ghostship is selling fantastic Cycles-based materials, and they are a good start.
Another good start is to look at Rendo's tutorials: you have really simple material setups, involving the Physicalsurface node, for which you only need a diffuse map and a bump map for a good start.
As a proof: I've only deleted those nodes, and unchecked both options (red arrow, I'm using my scripts for these two operations)
You end up with a decent, RTX-mode enabled render:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Afrodite-Ohki ( ) posted Mon, 29 August 2022 at 12:24 PM
If you're using Superfly, search&destroy any and all Ambient Occlusion nodes you find LMAO! They're buggy even without Optix - they're a workaround for non-indirect-lighting in Firefly.
Feel free to call me Ohki!
HartyBart ( ) posted Tue, 30 August 2022 at 7:51 AM
Thanks for the tip, Afrodite. There's now a free Poser 12 script on ShareCG that removes all Bumps. It would be simple to change the node name that target AO disconnect instead, for those who find they need that.
And to the Poser 12 developers, a big congratulations on the public release.
