Wed, Feb 5, 5:11 AM CST
Subject: Is there a way to display the XYZ Axis in the preview window
Uncanny_Film ( ) posted Thu, 01 September 2022 at 3:48 PM · edited Mon, 03 February 2025 at 10:08 PM
Is there a way to display the XYZ Axis in the preview window?
I believe there was a Script available with the previous version that allowed it to be displayed in the preview window. But I may be wrong.
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render |  Real-Flow | 3DCoat | Speed Tree | Adobe Premiere  |  Adobe After Effects |  Adobe Audition |  Adobe Photoshop
NikKelly ( ) posted Sat, 03 September 2022 at 7:50 PM
Scene XYZ ? Wasn't there a freebie with three orthogonal lines, or could you make one from Poser primiti8ves ??
Uncanny_Film ( ) posted Sun, 04 September 2022 at 7:03 PM
NikKelly posted at 7:50 PM Sat, 3 September 2022 - #4443888
Sorry, I do not understand. I don't want to make one. I want one to be present in the viewport. So when I change camera angles I'll know the XYZ Axis. I switch between different viewports a lot when animating. It gets a little tedious constantly hitting the undo when I accidentally change the dial of the wrong Axis I want.
NikKelly ( ) posted Sun, 04 September 2022 at 10:52 PM · edited Sun, 04 September 2022 at 10:52 PM
You mean like an aircraft's 'horizon ball' thing ?? If Poser cameras have that, sorry, I cannot find it...
FWIW, a two-minute whatsit: Library, props, Poser primitives' box. Drag into scene. Select box_1. Scale to 50%. Duplicate. Select box_1, duplicate again.  Select box_1, x-scale 500%, xTran positive until just clear of #2 and #3. Select box_2, y-scale 500%, yTran positive until just clear of #1 and #3. Select box_3, z-scale 500%, zTran positive until just clear of #1 and #2. Colour-code #1~~#3 to taste. Their 'show in ray-trace' [  ] (no) only seems to work for Firefly, which is unfortunate...
Y-Phil ( ) posted Mon, 05 September 2022 at 6:53 AM
Uncheck the three:
* Visible in Raytracing
* Visible in Camera
* Cast Shadows
It will remain visible in the Pose room, only.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
dadt ( ) posted Thu, 15 September 2022 at 3:33 AM
Try turning on display/guides/vanishing lines.
Uncanny_Film ( ) posted Tue, 11 October 2022 at 1:25 PM
Ok, Thanks to all for the suggestions.
LastQuest ( ) posted Tue, 11 October 2022 at 2:54 PM · edited Tue, 11 October 2022 at 2:54 PM
( Optionally )Turn on Direct Manipulation .....
Uncanny_Film ( ) posted Fri, 09 December 2022 at 10:33 PM
LastQuest posted at 2:54 PM Tue, 11 October 2022 - #4446427
Yeah, I use that a lot actually. But I wish it was labeled (XYZ).
jjk ( ) posted Sun, 11 December 2022 at 10:48 AM
Simple memory hook: XYZ = RGB, meaning:
X-Axis = Red
Y-Axis = Green
Z-Axis = Blue
It works this way in a lot of programs: Blender, Unity, even in Minecraft.  I have never encountered an exception.
Uncanny_Film ( ) posted Fri, 16 December 2022 at 4:21 PM
jjk posted at 10:48 AM Sun, 11 December 2022 - #4451454
X-Axis = Red
Y-Axis = Green
Z-Axis = Blue
Okay, Thanks
