Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
NikKelly posted at 7:50 PM Sat, 3 September 2022 - #4443888
Sorry, I do not understand. I don't want to make one. I want one to be present in the viewport. So when I change camera angles I'll know the XYZ Axis. I switch between different viewports a lot when animating. It gets a little tedious constantly hitting the undo when I accidentally change the dial of the wrong Axis I want.Scene XYZ ? Wasn't there a freebie with three orthogonal lines, or could you make one from Poser primiti8ves ??
Win10 - AMD 2nd Gen Ryzen Threadripper 2950X, 16-Core, 32 Thread 4.4 GHz - 128GB Ram - X2 GeForce RTX 3060 Ti - 3D-connexion
Poser 12 | Octane Render | Real-Flow | 3DCoat | Speed Tree | Adobe Premiere | Adobe After Effects | Adobe Audition | Adobe Photoshop
You mean like an aircraft's 'horizon ball' thing ?? If Poser cameras have that, sorry, I cannot find it...
FWIW, a two-minute whatsit: Library, props, Poser primitives' box. Drag into scene. Select box_1. Scale to 50%. Duplicate. Select box_1, duplicate again. Select box_1, x-scale 500%, xTran positive until just clear of #2 and #3. Select box_2, y-scale 500%, yTran positive until just clear of #1 and #3. Select box_3, z-scale 500%, zTran positive until just clear of #1 and #2. Colour-code #1~~#3 to taste. Their 'show in ray-trace' [ ] (no) only seems to work for Firefly, which is unfortunate...
Uncheck the three:
* Visible in Raytracing
* Visible in Camera
* Cast Shadows
It will remain visible in the Pose room, only.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Yeah, I use that a lot actually. But I wish it was labeled (XYZ).( Optionally )Turn on Direct Manipulation .....
Okay, ThanksSimple memory hook: XYZ = RGB, meaning:
X-Axis = Red
Y-Axis = Green
Z-Axis = Blue
It works this way in a lot of programs: Blender, Unity, even in Minecraft. I have never encountered an exception.
Is there a way to display the XYZ Axis in the preview window?
I believe there was a Script available with the previous version that allowed it to be displayed in the preview window. But I may be wrong.
