Wed, Jan 8, 12:15 AM CST
Subject: Grandmaster(M4) to L'Homme
willyb53 ( ) posted Tue, 06 September 2022 at 7:02 PM · edited Mon, 06 January 2025 at 8:06 PM
WIP Converting M4 Textures to L'Homme
:D
RedPhantom ( ) posted Tue, 06 September 2022 at 8:28 PM
Site Admin
Very nice. I'd love to convert some of M4's textures to L'homme.
RobZhena ( ) posted Thu, 08 September 2022 at 4:54 PM
What happened to your TT work on La Femme? At one point when DCArt started converting V4 and Genesis 2 characters to La Femme, she let slip that a texture transformer module had been created for La Femme. Never a word more was heard. Did Rendo catch and kill? No TT module emerged. I hope the L’Homme project  works out.
willyb53 ( ) posted Thu, 08 September 2022 at 5:21 PM
I do have a TT module for V4 to LaFemme, call it a TTLight, only does torso limbs and head.  The last I heard, Rendo had someone working on a V4 to LaFemme, so I stoped development.  Rendo DID NOT kill or even speak to me about what I was doing.  I just thought if they were paying someone to do it, I would not.  Only problem I have with the V4 module is the damn nose plugs on so many of the V4 textures
primorge ( ) posted Thu, 08 September 2022 at 5:48 PM
How does it work? Is the result redistributable? Everything I've ever seen out of TT looks off in some way, things that you could just fix easily in a 3d painting software or an image editor, nipple alignments, nostril placement, etc. As a matter of fact it always seems to be the nostrils are horribly wrong. The advantage must be a distribution safe version sort of like things people used to do with figure obj files and RTEncoder. Because otherwise results look better for placement just via manually altering the textures themselves, well I mean if you have a little experience doing so. You can easily clone stamp those nose occlusion "plugs" away in a matter of minutes. It must be a redistribution thing that's the advantage?
primorge ( ) posted Thu, 08 September 2022 at 5:57 PM · edited Thu, 08 September 2022 at 6:00 PM
Like in the image above the nipples are misaligned. Why not just fix that by clone stamping, copying the original nipple to a new layer, moving into the proper position on the new target uvs and blending via clone stamping? The hair might be a little tricky though. I guess if you edit it in such a manner, fixing those things, it would be a copyright violation?
primorge ( ) posted Thu, 08 September 2022 at 6:02 PM
I don't know. I was looking at TT but frankly the results never look good. Halfway good isn't good enough.
willyb53 ( ) posted Thu, 08 September 2022 at 6:11 PM
As I stated in the original post, it is w WIP
Results ARE NOT redistributable unless you won the copyrights to the original textures.
If you do not like the results, you should prbably not get TT.
primorge ( ) posted Thu, 08 September 2022 at 6:19 PM
Oh I see. The results aren't redistributable. I won't get TT. I have mudbox and photoshop. That doesn't help fit to UVs of course., but as far as fixing things and painting textures for original UVs, pretty good. Maybe this is something where AI could come in handy. Just sharing my thoughts about what I see and have seen from TT. To each their own.
Rhia474 ( ) posted Thu, 08 September 2022 at 6:56 PM
For those of us who aren't in the know, what is TT, please? Thank you!
primorge ( ) posted Thu, 08 September 2022 at 7:09 PM · edited Thu, 08 September 2022 at 7:11 PM
Rhia474 posted at 6:56 PM Thu, 8 September 2022 - #4444154
https://www.renderosity.com/rr/mod/bcs/?search=Texture+transformer&newsearch=1
It's from the same developer as Blacksmith3D software. You can refit textures from one uv set to another. Sort of a Holy Grail/Unicorn type thing. I've never used it, only have ever seen examples. And not that many to boot, so I suppose I can't judge the software too harshly. You can win a copy along with Blacksmith3D if you happen to place in the upcoming Rendo Halloween contest. Blacksmith is developed to be very Poser formats friendly. I believe TT may be bundled with BS3D pro.
hborre ( ) posted Thu, 08 September 2022 at 9:32 PM
Texture Transformer is a program similar to the old Universal Texture Converter and Texture Converter 2 that were sold at DAZ 3D.  It's probably a poor man's version of the Blacksmith3D app except it's a one-time purchase and you add module packs for the different model conversions.  Unlike the older converter programs where the algorithm redraws the texture maps, this one requires a model with the texture already loaded.  You need to simplify the texture maps in the Material Room first; don't attempt to add fancy mathematical node arrangements or SSS, it will not recognize those connections and totally screw up the converted output.  And forget about converting into Cycles; its main focus is building the Material files around the PoserSurface node.  Do you want PBR?  Expect to go into the Material Room and get your hands dirty rebuilding the nodes.
RedPhantom ( ) posted Fri, 09 September 2022 at 8:04 AM · edited Fri, 09 September 2022 at 8:06 AM
Site Admin
hborre posted at 9:32 PM Thu, 8 September 2022 - #4444158
This is no longer correct. You can use a cr2 file to get the maps, but you can also use a pz2, mc6, or a duf file to get the textures. Output you can choose between mc6, pz2 or Duf and choose image format, png or jpg. IIRC it can also use more complex shaders. I'll confirm that when I can get Poser to load. It seems to think it has today off.
RedPhantom ( ) posted Fri, 09 September 2022 at 8:52 AM
Site Admin
Okay, Poser finally loaded. It was able to work with a complex shader, but it transformed to a basic one, using only the maps.
hborre ( ) posted Fri, 09 September 2022 at 9:44 AM
I dusted off TT last night and yes, it is capable of recognizing the other formats you mentioned.  It's been a long time since I used it that I'd forgotten.  And as you found out, the app only returns a basic conversion; that is why I strip down the texture shaders to their basic setup in the material room, run TT, and then rebuild the shaders with EZSkin 3.  There is less likelihood of missing texture maps and reduces conversion processing time.
DCArt ( ) posted Fri, 09 September 2022 at 10:46 AM
RobZhena posted at 4:54 PM Thu, 8 September 2022 - #4444143
It's been my experience that Poser or DAZ Studio shaders with "advanced" nodes and features do not convert automatically. They are hit or miss, and many throw Texture Transformer error messages. Also, Texture Transformer will not convert normal maps that are connected to the Poser Surface node's "gradient bump" connection with Tangent Space selected as format. And as someone has already mentioned, PBR type maps, such as metallic and roughness (which SuperFly works much better with) are not recognized by Texture Transformer. So you have to create very basic shaders that connect the unrecognized map types to the Color input of the Poser Surface node and take it from there.
Hence the main reason that the conversion kits have been on hold. Conversion kits were created to convert M4, V4, G3F, G3M, G8F and G8M to La Femme and L'Homme, HOWEVER ... Texture Transformer is not fully compatible with SuperFly shaders as it currently stands. 3Delight materials convert reasonably well, but iRay conversions are hit or miss as well.  It isn't a "one-click" conversion solution the way it is, which no doubt would be problematic for beginners.
RobZhena ( ) posted Fri, 09 September 2022 at 12:28 PM
Thanks for the update, DCArt.
FVerbaas ( ) posted Sun, 11 September 2022 at 3:43 AM
Forum Coordinator
Thank you for the clarification, DCArt, but frankly said I think all one is after in the end is a set of image files. iRay, Superfly, 3Delight, Firefly are just different media, like watercolors, gouache, acrylic and oil paint are for good old real painting. They all yield different results for the simple reason they are based on different technologies. On top of that the Poser engines and the DAZ engines are designed to work in different environments with different post processing. Trying to convert complex shaders to get the same result is a waste of time. I therefore wonder if it is worth holding a release. If the product  is not for beginners, so be it.
As a minimum one needs the skin of body, head and limbs cut, stretched as appropriate and then sewn and laid out as needed for your target figure.  From there they can be copied into an appropriate shader for the target figure or fed into EZSkin to build one from scratch. Irises, nails, brows and lashes are options that can go same route. If the conversion tool can do this also even the better. I really doubt converting teeth, tongue and what else is worth spending time on. Noted exception are the male genitalia but they usually are a separate figure anyway.
DCArt ( ) posted Sun, 11 September 2022 at 10:18 AM
FVerbaas posted at 3:43 AM Sun, 11 September 2022 - #4444290
Yes I agree that all one is after are the image files. However, as stated above, Texture Transformer doesn't recognize some image types and will not convert them directly. For example, if the original figure has normal maps that are connected to the Poser Surface node through connection with the Gradient Bump connection and the Tangent type selected, Texture Transformer will not convert them. Instead, the user will need to create a temporary MAT file that connects the Normal map to the Color input of the Poser Surface Node and convert that separately.
Same for other map types that might be in the original figure that the Poser Surface node will not recognize.
So there appears to be some sort of misunderstanding about what I'm trying to say. The Texture Transformer conversion kits basically project textures from the original figure (say, V4) to a version of La Femme that is morphed to match V4 exactly in shape and size. So in that respect, the user doesn't need to match UVs at all.
Basically, Texture Transformer recognizes the types of maps that you used to assign in the Simple material view. But if anything passes through other FireFly nodes before connecting to the Poser Surface Node, Texture Transformer will throw an error. Likewise, if you are trying to convert textures that connect to the Physical Surface Node or the Cycles node with Principled BSDF, they won't be converted either, because Texture Transformer was last updated in 2016 before SuperFly was in its prime.
Yes, I realize the ultimate goal is to generate textures. But Texture Transformer doesn't recognize several map types commonly used today, and that is what needs updating in the utility (not the transformer kit). Otherwise, users will need to create custom MAT files to generate all of the textures in the source object - and that is the part that beginners with no experience with creating MAT files would have difficulty with.
willyb53 ( ) posted Sun, 11 September 2022 at 4:24 PM · edited Sun, 11 September 2022 at 4:24 PM
Just to Join back in :D
Some members with no knowledgeof TT do not realize that given a useful  TT pack, you can do the conversion of a texture in minutes without using any other software
Shaw (m4) to L'Homme
There are two ways to use the (head/torso/limbs) image maps reasonably quicklly
1. use the output pz2/mc6 files to load the images and then use an mc6 file to insert the distribution textures  that were not converted and then use ezskin3 to set up a superfly mc6
2. load the basic L'Homme and load the images in the material room
Both will work, but the first will get the bump maps from the conversion (TT converts these automaticly)
Neither require more than a small amount of knowledge of the material room
Superfly render of Shaw
