Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
RSR files are no longer used in Poser so there is really no need to create or use them. You have legacy models in Poser that you can use and modify through morphs to create your own characters. But if you are interested in creating your own from scratch, then you need other applications like Blender (Freeware) for such endeavors. You will need to be very specific about your intentions because Poser is not really a model-creation program.
RSR files are no longer used by Poser. The RSR was a proprietary format used by poser for thumbnails. It's no longer supported. PNG files are used for thumbnails in poser starting with version 5.
As for tutorials each of these steps below would each constitute a tutorial of it's own. I've covered this process in webinars. They're probably posted someplace on YouTube.
As with all things Poser there are many ways to do whatever you're trying to do. Here's a rough outline of four figure creation techniques in Poser
=== The Modern Way ===
1. Model the figure in an external modeler such as Blender. (The Sculpt)
2. Export the OBJ at Poser scale which is much smaller than Blender. 400:1 or so.
3. Import the OBJ into Poser
4. Take the figure into the Setup Room
5. Load a skeleton that's similar in dimensions to your new figure
6. Adjust bones' positions as necessary. Add or remove bones as needed. (Rigging)
7. In Pose room edit weight mapping to achieve proper bending (Weight Mapping)
=== Slightly Old School ===
1. Sculpt the model as above
2. In the Model define all the body part groups using the Poser naming scheme which is WEIRD. (Cutting up the figure)
3. Import the grouped OBJ into Poser
4. Spawn props from the OBJ with the grouping tool
5. Use the Hierarchy Editor and [Apply Standard Hierarchy] and then [Apply standard rotations]
6. [Create New Figure] on the Hierarchy editor
7. The figure is created in the "New Figures" folder of the library.
8. Load the "New Figure" and adjust the joints with the Joint editor as needed
=== Really Old School Method ===
This method does not work for weight mapped figures
1. Sculpt and group the OBJ as with the slightly old school method. The shape needs to be vary close to the "donor figure"
2. In a text editor open the figure's CR2 file.
3. Edit the 2 OBJ references to point to your newly created OBJ. (Hacking the CR2)
4. Open the newly hacked figure file in Poser and adjust joint as necessary
=== The Old Timers Might Remember This One ===
Does not create weight mapped figures
1. Find a copy of PHIBuild.exe (Good luck)
2. Use Phi Builder to create a PHI file for your figure.
3. In Poser File > Import Heir File ..
4. Adjust the joints on the created figure.
These are rough outlines there's way more to rigging a character. The easiest way is the modern way.
Here's a Setup Room Tutorial covering clothing. The concepts are the same for a full figure:
https://www.renderosity.com/premium-tutorials/133/setup-room
Weight Mapping
https://www.renderosity.com/premium-tutorials/137/la-femme-weight-mapping
And just in case: you may convert RSR to PNG thanks to this tools, provided by Dizzi.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
Weight Mapping
Thanks Chuck, as these are two things I've never tried.
_______________
And I forgot to explain that it's recursive: launch it at the root of a runtime, grab of coffee/tee, put your feet on the desk and... voila
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Ohhhh, that recursive feature is nice. I don't think I've ever had that issue, but it's certainly good to know.
Of course now-a-days I rarely use anything old enough to have RSR files for thumbnails, but you never know when you'll need to reinstall an older product on a new computer, so it can still come in handy.
_______________
Miss B posted at 5:36 PM Wed, 7 September 2022 - #4444098
Now that you wrote that, I launched my "Everything" program and asked it to search for *.rsr: 26727 files, almost all of them in my old poser7 runtime....Ohhhh, that recursive feature is nice. I don't think I've ever had that issue, but it's certainly good to know.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
No the RSR files remain. But as I'm using "Everything", deleting all RSR in a complete hierarchy is a matter of secondsDoes that program delete the old RSR files? I seem to recall that it is not as thorough in cleaning up files afterward. That's why I use P3DO, it removes all converted RSR files.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
hborre posted at 8:42 AM Thu, 8 September 2022 - #4444119Where does one find this "Everything " app? Sounds intriguing. Does it work in windows?No the RSR files remain. But as I'm using "Everything", deleting all RSR in a complete hierarchy is a matter of secondsDoes that program delete the old RSR files? I seem to recall that it is not as thorough in cleaning up files afterward. That's why I use P3DO, it removes all converted RSR files.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Y-Phil posted at 3:22 PM Thu, 8 September 2022 - #4444140What's astonishing with "Everything": it finds files as fast as you can type...hborre posted at 8:42 AM Thu, 8 September 2022 - #4444119Where does one find this "Everything " app? Sounds intriguing. Does it work in windows?No the RSR files remain. But as I'm using "Everything", deleting all RSR in a complete hierarchy is a matter of secondsDoes that program delete the old RSR files? I seem to recall that it is not as thorough in cleaning up files afterward. That's why I use P3DO, it removes all converted RSR files.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
Thanks for the link and information. I'll check it out.
Thanks for the link @hborre, as I didn't know about this goodie.https://www.voidtools.com/downloads/
Works on Windows
_______________
Friends, I'm new user of Poser and wish I could create my own characters. However, I'm having a lot of difficulties.
One is to create and edit the "rsr" files. Someone can help me.
And can someone help me with a tutorial on how to create my own characters???
