Sun, Nov 17, 11:38 AM CST
Renderosity Forums / Poser 12
Welcome to the Poser 12 Forum
Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
Subject: problem with Poser 12 interface
Tipol ( ) posted Sun, 30 October 2022 at 1:15 PM · edited Sun, 17 November 2024 at 11:22 AM
Have you ever had this problem, the main window normally in the center of the interface is fixed at the top instead of the middle. Impossible to fix it in the center as soon as you try after having detached it, it reattaches at the very top. I tried closing everything and shutting down the computer but that didn't fix the problem. Does anyone have the solution?
RedPhantom ( ) posted Sun, 30 October 2022 at 2:25 PM
Site Admin
I Haven't had that issue particularly, but I have had issues with moving things and not getting them back in the right spot. To fix this, you may need to reset the UI.
Go to edit>general preferences>interface tab and click on launch to factory state. Then restart Poser.  Now do your customizations of where you want everything and uncheck all the Drag Docking enabled for each window. Then use a UI Dot to remember the setup in case something gets moved in the future
Tipol ( ) posted Sun, 30 October 2022 at 3:16 PM
yes it works, thank you very much ! :)
RedPhantom ( ) posted Sun, 30 October 2022 at 3:18 PM
Site Admin
You're welcome
hborre ( ) posted Sun, 30 October 2022 at 4:17 PM
Uncheck Drag-Docking Enabled.
