Poser 12 F.A.Q (Last Updated: 2024 Oct 22 2:54 pm)
I Haven't had that issue particularly, but I have had issues with moving things and not getting them back in the right spot. To fix this, you may need to reset the UI.
Go to edit>general preferences>interface tab and click on launch to factory state. Then restart Poser. Now do your customizations of where you want everything and uncheck all the Drag Docking enabled for each window. Then use a UI Dot to remember the setup in case something gets moved in the future
You're welcome
