Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
I have the same issue with my Cintiq... In my case, the Cintiq must be the primary Display. I am not sure if Huion is the same. I have a XPen Display that does not have that issue.
NOTE: Poser will remember the location of some screens (by Coordinate Location) which will impact where some windows open, when moved. In those cases, I use the UI Dots to remember Window Locations and then use one for when I use the Tablet and another when I do not. That might solve your issue with the Huion (did not with the Citiq for me)
ratscloset
aka John
Thanks, at least I know I'm not alone.
I wonder if using Poser 12 or upgrading to Windows 11 would fix it.
My Huion is not my primary display. My primary display is a LG doubleheight monitor, so it really doesn't work very well to try and duplicate it on the tablet.
I don't understand why Poser palettes pop up on the tablet, anyway. I've occasionally the problem with other software, but only if I've put it on the tablet. I never put any part of Poser on my tablet.
I have a huion and on windows 11 and so far no problems regarding things popping up. like you i dont always keep my drawing tablet on, its only on for use. took me awjile to work out the whole thing about primary display, but now i have my drawing screen set up below my main monitor so it acts like the lower half of a screen. all i can think is to check your drawing tablet is where your computer think it is. but unless things are dragged to it you should not have this problem.
I have a dual monitor system, and a Huion drawing tablet that acts as a third monitor when it's on. It's only on when I'm drawing.
The problem I'm having is that Poser 11 keeps popping up menus on the Huion tablet...even when it's off. For example, when I click "render settings," the palette comes up on the Huion tablet. I can move it another monitor, but the next time it pops up on the tablet again.If the tablet is off, I don't see the palette at all.
Rebooting the computer with the tablet off fixes the problem...as long as I don't turn the tablet on again.
This is really annoying. Never had a problem until I upgraded to the latest version of Windows 10, so I think that might be the cause.
Is there any solution to this?
