Mon, Jan 27, 2:05 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Working with high poly Hair slows everything down
JagoBC ( ) posted Mon, 07 November 2022 at 12:17 AM · edited Sun, 26 January 2025 at 11:57 PM
I'm using some older neftis hair on a model and every time I click the mouse, it seems to want to redraw every strand of hair, slowing the editing process down (and raising the frustration levels to new heights). I've tried making the hair invisible during editing to no avail and have just settled on saving two versions of my model, 1 w/hair, 1 w/out, and getting everything ready to render using the first and substituting the second at the last minute. But there must be some way to work with hair without these limitations! I just can't figure it out.
primorge ( ) posted Mon, 07 November 2022 at 8:45 AM · edited Mon, 07 November 2022 at 8:45 AM
Have you tried a different preview styles for the hair? Outline for instance. Or changing the preview tracking mode to fast or box? The option is at the bottom of the preview tab, first shaded sphere icon...
primorge ( ) posted Mon, 07 November 2022 at 8:51 AM · edited Mon, 07 November 2022 at 8:51 AM
Also in render setting, preview tab uncheck Enhance MultiLayer Transparency in Transparency Display options if you have it checked, this causes a bit of lag in preview if used with a heavy hair...
NikKelly ( ) posted Wed, 09 November 2022 at 8:14 AM
Thank you, Primorge.
FWIW, I used one of the bundled 'wigs' for LaF that looks okay but did not significantly slow editing.
Also, just do lighting 'with wig' test renders of head+shoulders to mitigate weary wait...
Another 'gotcha' is complex foliage such as a common-or-garden lawn: 35 MB OBJ ??? I wrangled that monster by using Poser's ground plane and OBJ's bump-map set to 'displacement'. Just mind you set appropriate displacement scaling there, and  'displacement bounds' in figure properties. With care you can get 'Elephant Grass'...
RedPhantom ( ) posted Wed, 09 November 2022 at 6:09 PM
Site Admin
A couple of things I might add to primorge's post, you might turn off the hardware shading. And turn down your preview resolution to 256 or 512. It will look bad on display but will make the scene more workable.
