Mon, Jan 20, 11:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Poser 11 - How to find what geometry file a figure is using?
learning3d ( ) posted Tue, 08 November 2022 at 11:31 PM · edited Mon, 20 January 2025 at 11:10 AM
Is there a way to find out what geometry file is being called by a figure? This would be for UV mapping purposes, to find the original .obj a figure is using.
Thanks.
dadt ( ) posted Wed, 09 November 2022 at 1:54 AM
Open the figures CR2 file in a text editor such as Notepad and the information is at the top of the file
FVerbaas ( ) posted Wed, 09 November 2022 at 6:42 AM · edited Wed, 09 November 2022 at 6:43 AM
Forum Coordinator
In a submenu of the scripts menu there is a choice 'listfiles'. It yields a list of all external files used in the scene.
RedPhantom ( ) posted Wed, 09 November 2022 at 6:47 AM
Site Admin Online Now!
There is a script called list files. I believe it’s under scripts>utilities. It will list and geometry files and texture files loaded into the scene and tell you where they are located. Since it works on the current scene, you will need the figure loaded.
Many figures do come with their own templates, but finding those can be difficult since there is no standardized location and too many have super original names like “torso template”.
NikKelly ( ) posted Wed, 09 November 2022 at 7:59 AM
Note: If eg CR2 file exceeds ~100 Kb, 'Notepad' may become unstable or 'hang'. If so, open file with eg Wordpad, which lacks such constraints...
I ran into this 'hacking' mis-exported OBJ files which had 'many' material regions, but only one (1) material name...
( And, d'uh, make a 'safety' copy of original file, to be sure, to be sure... )
There are also 'Classic' utilities such as Phil_C's wondrous CR2 editor...
hborre ( ) posted Wed, 09 November 2022 at 12:56 PM
Notepad++ is what you should be using, not the MS Notepad that comes with the OS.  It's much better and doesn't alter script integrity.
SamTherapy ( ) posted Wed, 09 November 2022 at 2:56 PM
John Stallings made Cr2Editor, IIRC.  Doubt you'll be able to find it now, sadly.
primorge ( ) posted Wed, 09 November 2022 at 3:31 PM · edited Wed, 09 November 2022 at 3:31 PM
SamTherapy posted at 2:56 PM Wed, 9 November 2022 - #4448814
Internet Archive Snapshot of Morphography Freebie Poser Utilities Page, Stalling's Cr2Editor 1.5.
https://web.archive.org/web/20190812005225/http://www.morphography.uk.vu/dlutility.html
DL link is working and Cr2Editor 1.51 tested and works in Win10
primorge ( ) posted Wed, 09 November 2022 at 3:43 PM
...MorphMan40, on that page, also works. It's kind of antiquated though. Sometimes useful for batch deletes. Renaming of external/internal names can be done in Poser itself via dial settings dialogue. I use Dimension3d's Binary Morph Editor for pmd perusal and manipulation.
I've never had Cr2Editor crash from anything, in the times I've used it. I just use a text editor for Poser file manipulations. I use EditPad lite. I've never come up against any difficulties using it, including manually hacking pmd injections and creating geometry switching dials.
infinity10 ( ) posted Thu, 10 November 2022 at 7:55 AM
I believe Ken1171 has some commercial utilities at the Renderosity store for Poser12 which can help with finding referenced files.
Eternal Hobbyist
learning3d ( ) posted Mon, 14 November 2022 at 2:36 PM
Thanks everyone!
