Unfortunately, the only thing to do is resave the pose without including the scales. And remember the size of your fairies so you can fix them easily when you find a new one.
It may work: a pose file simple reset the scale parameters back to 100%, if the parameters are stored in it.
That being said, many pose files also moves the figure/prop back to the origin as well, and it's so wrong to do so.
So that, in this case, you may use a text editor to remove the parameters from the PZ2 file, a text editor or PoserEd.
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Win11 on i9-13900K@5GHz, 64GB, RoG Strix B760F Gamng, Asus Tuf Gaming RTX 4070 OC Edition, 1 TB SSD, 6+4+8TB HD
👿 Mac Mini M2, Sequoia 15.2, 16GB, 500GB SSD
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
what about saving your fairies off into a folder in the Characters library and giving them a name with an _ and the percentage size (i.e. fairy1_10 for 10%) That way if it goes to full size when you pose it at least you'll remember what scale to go to. It might mean a bit of repositioning though.
Just an idea.
I have all the fairy's saved so i can reload them at any time at the 40% scale. the issue is some poses trigger the whole thing to scale up and that messes with the hair and clothes so it can get pretty messy depending on how much i have in a scene. the V4 fairys work great its the Mike 3 ones that play up mostly
part of the work i do for my comics is working with fairy's. so i made the figures up and scaled them down before saving them and mostly this works fine. however some poses make them go back to full scale and this becomes a pain. dose anyone have any advice about this? or am i better using full size characters and scaling up all the scenary? (however i cannot do that when i have fairy's interactiong with humans size people)
