Fri, Nov 22, 4:10 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: fustration
theeverman ( ) posted Sun, 28 October 2001 at 9:29 AM ยท edited Fri, 22 November 2024 at 11:08 AM
why????? for some very odd reason, I cant get any textures i get or make to work properlly in the P4 models!!!!! they blur..... I did all the common steps on the materials menu and screen, but no success.... does anyone have a clue? thank you The everman
theeverman ( ) posted Sun, 28 October 2001 at 9:34 AM
this is a tex I got from the net.... The Everman
nyar1ath0tep ( ) posted Sun, 28 October 2001 at 1:48 PM
I'm just a newbie here myself, but try these tips: 1. Remember to check anti-alias in render options. 2. Export as tiff to avoid pixellation (squiggly, blurry edges). 3. Use the largest texture maps your memory will allow - usually 2000X2000 or larger.
theeverman ( ) posted Sun, 28 October 2001 at 3:55 PM
thanks, I'll try... can you see the lips? in the texture, they are red, and you can just see them below the original lips in the model... as if poser were using both textures.....
Jim Burton ( ) posted Sun, 28 October 2001 at 4:07 PM
Hi Theeverman!- Oh, you have to set all the material colors to white, did you do that? Anything other that white will bias the texture map. PS: try setting your camera to longer lens, say 105 mm, Poser's default is wide angle, make everthing look bad closeup!
theeverman ( ) posted Sun, 28 October 2001 at 4:41 PM
nope... that didnt work... lips still superimposing the texture... but thanks for the great rendering tips! they're great!!!!! The Everman
pjanak ( ) posted Mon, 05 November 2001 at 9:16 PM
Jim Burtons suggestion is the correct one. If the object has any color to it other than white, yiu will see the base color affect the texture color. Slect th lips and color then white.
pragask ( ) posted Wed, 07 November 2001 at 4:23 AM
If you're saving the image as a jpg file, there is an option of compression setting to make during the save process . Choose the 'best' or 'no compression' option to avoid blurring .
theeverman ( ) posted Wed, 07 November 2001 at 12:44 PM
thanks everyone... i've now managed to use those darn textures. hehehe got a couple of renders in the galery too! thanks all
