Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 16 2:29 pm)
I never took the time to wrap my head around Matmatic, I always thought loom was mighty impressive though. That being said, it might work with 11. It might need Snarlygribbly's AVFix...
https://www.poserlounge.nl/PLWP/fix-for-scripts-in-poser-11-2/
Still no guarantee it'll work with AVFix.
I would try Poser 8 if it were me but then you might run up against the Library problems.
Barring all else you could Site Mail BB and cross your fingers that he's at the lower range of Curmudgeonly Amnesiac mode.
It's a lot of hoops/hopes.
I'm still here, low key lurking. I could probably get matmatic running in P12, but I don't have P12 myself, so as to try it.
The loom script is complicated but almost only deals with generating patterns. Such pattern generating nodes are not affected by SuperFly lighting rules/restrictions.
I do recall some problems with the Loom pre-dating the general adoption of built-in GC. You'd probably want all that stuff ripped out.
Hmmm. Would Rendo want to let me have P12 for free so I could do the updates?
I did load some loom generated material in P12 and rendered in both Superfly and Firefly. For the most part, I did get decent rendered images despite some connector 'irregularities' between some nodes. But, my God, I completely forgot how extensive the Material Room nodes could be. My question is why pursue creating such textures with such an overhead.
I'm hooked up for P12 (thanks Jenn!).
@hborre - The loom is best used to create a pattern from nothing (which is expensive and complicated), and then render/capture that pattern as a tiling texture image, which you can do right from Poser. Thereafter you just use the image.
Exciting news!
That makes me wonder how much effort it would be to bypass Poser and generate the texture image directly. Just hypothetically.@hborre - The loom is best used to create a pattern from nothing (which is expensive and complicated), and then render/capture that pattern as a tiling texture image, which you can do right from Poser. Thereafter you just use the image.
