Thu, Jan 30, 12:12 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Need to download the Poser 11 runtime again
rokket ( ) posted Wed, 28 December 2022 at 9:45 AM · edited Thu, 30 January 2025 at 11:46 AM
Where can I download another copy of the Poser 11 Pro runtime? I made some very stupid errors when I was installing that behemoth and I need a do over...
donnena ( ) posted Wed, 28 December 2022 at 10:26 AM
https://www.posersoftware.com/downloads/11
here ya go!  you'll need your serial number
Andy!
rokket ( ) posted Wed, 28 December 2022 at 10:34 AM
Thank you! I found it right before you posted. I started downloading, but I am at work and the bandwidth is being shared with about 4000 people. I might give up after the first four files and just finish at home!
rokket ( ) posted Thu, 29 December 2022 at 8:17 AM
I wish there was still an installer for all this stuff. I am not sure how to unzip it into a runtime...
hborre ( ) posted Thu, 29 December 2022 at 9:12 AM
Online Now!
You can use Poser's native installer but it doesn't do the batch installation nor distinguish between which runtime folders you want to unzip.  I agree it's a tedious process and you can wind up with duplicate files if you don't keep track.
rokket ( ) posted Thu, 29 December 2022 at 9:12 AM
I figured it out. You can do it inside Poser 11 by selecting install from zip file...
hborre ( ) posted Thu, 29 December 2022 at 9:15 AM
Online Now!
Pet peeve, double-check that all the zip files are consistent and in the same hierarchy structure, otherwise you will have folders either nested within runtime folders or completely outside runtime folders.
rokket ( ) posted Fri, 30 December 2022 at 10:03 AM
I got everything installed.
How do I clean up duplicates, though?
