If you set the transparency level in Poser to maximum and minimum both at 100% they will import properly. If you did not do that, find the hair materials in Display>Display material summary, find the transparency map among them and double click on it to open it in the material editor. You will find that the transparency level is at 50% or less. Raise it to 100% and it will be fine.
Hallo i have one big hairy question When I import my pzr3 files in vue 4.01 everything work very fine. But only transmapped hairs. Kyoko mk2 for example -there is no transparency-if I set trans in material editor --I have ugly holes in the hair from some perspektives . In my older bryce 4, I know the settings,let it lock like in poser.(if someone want to know?) Here I search and cant find the answer .It is a little thing but a big problem make the differnce between the use of the good and much more faster vuerenderer. thank you SUN
