Poser 12 F.A.Q (Last Updated: 2025 Jan 08 5:19 pm)
I have it installed on 3 computers. You can only use one at a time. And there is a time limit as to when you can install it on another computer if for some reason you need to change where it is installed. I don't know what that time limit is.
Thank you for your replies, it makes things clearer.
I assume that if you want to install on a fourth computer you have to de-install from another one. I don't expect that I will but the reason I am thinking of installing on a second is because the computer I am using now is fairly old and getting a bit unreliable. If it does fail completely and I can't de-install from it I would still have two installations I could use.
There is no de-installation like there was for Poser 11 when it was sold by Smith Micro. You just can't install on multiple computers in a short time span. So if you install on the 3 computers and one dies as long as it has been a while since you last installed and ran it you should be fine. What they don't want is for you to install on 25 computers in a couple of days.
I'd like to install Poser 12 on 2 computers. I'd only only use it on one at a time and no-one else would use it on either machine. I don't know if this is allowed under the licence conditions.
