Fri, Nov 22, 3:36 AM CST
Subject: lighting advice
mr_red ( ) posted Sat, 11 March 2023 at 2:41 AM · edited Fri, 22 November 2024 at 3:11 AM
As much as i try i cannot get lighting to stick in my head and just find it hard to do anything but basic stuff. I would like to put a light in the lamp on the scene below but i'm just getting more and more fustrated by it. some advice please ( like your talking to an idiot because in this subject i am!)
EVargas ( ) posted Sat, 11 March 2023 at 6:31 AM
Hi, do you mean a light emitter material? Or a standard simple light (point light from the menu)? There is an old article about emitters, take a look and see what you think: https://www.posersoftware.com/article/522/poser-basics-how-to-use-light-emitters-in-poser
If you mean object / point light, I believe simple parent/child relationship will help you: https://www.posersoftware.com/documentation/12/Poser_Reference_Manual/BuildingScenes/Props/Changing_a_Parent.htm
EVargas.Art
mr_red ( ) posted Sat, 11 March 2023 at 6:54 AM
I just want light coming from the lamp in the bears paws. I will give them links a read thanks.
hborre ( ) posted Sat, 11 March 2023 at 7:51 AM
Are you using Firefly or Superfly?
mr_red ( ) posted Sat, 11 March 2023 at 8:12 AM
Firefly but i have poser 11 so either is workable
EClark1894 ( ) posted Sat, 11 March 2023 at 2:25 PM
mr_red posted at 8:12 AM Sat, 11 March 2023 - #4458108
Then use both solutions. But a point light parented and positioned in the flame is the most simple and direct solution.
hborre ( ) posted Sun, 12 March 2023 at 5:38 AM
You will be better off with the Point light, less noise if you render with Superfly, and use transparency instead of the glass in the lantern.
hborre ( ) posted Sun, 12 March 2023 at 5:42 AM
Your illumination should be low intensity and tinted either red or orange color.
mr_red ( ) posted Sun, 12 March 2023 at 8:25 AM
thanks for the help peeps
hornet3d ( ) posted Mon, 13 March 2023 at 3:55 PM
I love using Superfly but I have to say that in situations like this I tend to fall back into the old ways and use a point light, it just seems more comfortable.  I tend to use emission a lot more if there is a display involved which is quite often seeing my leaning to sci-fi for many of my renders.
